Home > Off Roading & Green Laning > Waffle boards
Waffle boards
With every used waffle board set I can find being a million miles away I'm looking at new tracmats and wondering if I could get away with the 38mm thickness or if being a fatty the FFRR needs the 50mm ones as I'm looking at getting the 1.4m to help with the fat front over hang Smile
I've seen done metal ones but decided against them due to weight and not bending back to their original shape on their own and just handling them would be a ballache i imagine when wet or cold! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142601 23rd Sep 2012 5:13pm
Budgie
Tracmat say that the 38mm will take 2500 kg, while the 50mm will take 3000 kg. So you should be OK with the 38mm version but I went for belt & braces and got the 50mm a few years ago. Wink
Post #142677 24th Sep 2012 11:18am
Fox
Where are you?
I have some waffle boards I don't use anymore.
Post #142707 24th Sep 2012 12:45pm
Up in Warrington Fox Sad
Though I'll be in Doncaster and then Kidderminster on Saturday Smile
A likely weight difference of 1kg all in them lol!
Do the tyres slip on them easily or are the surfaces roughed/sand impregnated so as to help as I'll be combining them with the MT/R's so they have wide fat slabs of rubber on them Smile
If each one can handle 2.5tonne then that should be great as they wont get that unless the thing bounces on them which i doubt i will be on my first proper big off road run! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142710 24th Sep 2012 1:01pm
Fox
I'll have to check when I get home as I've not had either of my 90s for a few years now and I've still got an amount of offroading kit laying around...
Some I had were smooth, some had grit bonded to one side for better traction.
The latter do give more grip, but also chew the tyres a bit of you get too much wheel slip.
Post #142715 24th Sep 2012 1:16pm
Cheers Fox Smile
So far the best price i can get is circa £50 for the 1.4m 38mm ones that are about 300mm wide or a smidging more which is more than enough for the 255's Rover wears Smile
Let us know what other bits you have as i may have some more as im still trying to get the front sump guard bought for her and fitted before we go there!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142719 24th Sep 2012 1:48pm
Fox
My stuff is all offroading gear in general.
So shackles, tow strops, winch sail, tow ropes, folding shovel, waffle boards, folding ground anchor, ViAir Compressor etc...
I've been falling over the stuff for years!
I've got a 6hp Warn winch motor off a 9.5XP I've had for three years too. It's still in the box!
When I got my GT-R I moved from offroading to track days and just forgot to put it all on ebay...
Post #142721 24th Sep 2012 1:59pm
Hmm a winch you say, what else would one need other than fairlead rollers to get that to fit into the L322 cradle? im guessing a drum?
I've got some shackles (took me ages to find a perfect one to mount round the tow hitch!) but ideally looking for a slot in type one like ive seen on some yank sites?? and a compressor?? how big are we talking??
If you get a chance scoot up a list in the forsale section and i'll cross post it on defender 2, fl2, rrs and d3/4 for you Smile
Going to have to go and count some pennies and crack some piggy banks me thinks!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142727 24th Sep 2012 2:15pm
Fox
It's just the motor.
Some people upgrade the 4.6hp Warn winches to the 6hp XP type, which is what this motor is.
Compressor is a ViAir thing that is quite powerfull and clips onto the battery.
It's about 20cm x 40cm x 30cm tall and has a big coiled pressure hose so you can reach all the tyres.
I took it around Morocco on a Land Rover thing and was very impressed with it.
I'll try and do you a list tonight.
Post #142732 24th Sep 2012 2:26pm
cheers fox mucho appreciated Smile
Post #142733 24th Sep 2012 2:33pm
Fox
I've run out of time tonight, it's dark and blowing a gale out there!
But a quick look revealed three waffles of the 38mm variety and a 50mm with grit on one side.
Will do a proper inventory tomorrow, sorry for the delay.
Post #142808 24th Sep 2012 7:47pm
Fox there's no need to apologise I appreciate the effort Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142811 24th Sep 2012 7:58pm
Fox
Righto...
3 x 38mm waffle boards
2 x 50mm waffle boards (with grit on one side)
2 x David Bowyer Chock Tracks (fold up tracks/high lift base/wheel chocks, cost around £200!!!)
VIAIR portable compressor with air hose (powerful one for offroad tyres, ie large ones)
ARB heavy duty winch blanket
Long tow rope for offroad recovery
Tree strop
Assorted shackles
Folding shovel
Folding saw
Portable folding ground anchor for winching
4 spotlights with covers
2 new spotlights still in boxes
Warn winch hand control
New 6hp Warn XP winch motor
300 Tdi Defender fan belt, A frame ball joint, 2 x wing mirrors, viscous fan unit (all new)
Series II rear door hinge, rubber gaitor for gearstick, full polybush kit, Hub spanner and other bits...
4 20l Army style jerry cans (as new) that have had diesel in them.
That's about it other than a few bits and bobs.
If it's of any interest pop my a PM with your contact number and I'll give you a call.
Bare in mind I am near Chelmsford in Essex.
Post #143037 25th Sep 2012 7:51pm
ooooo
PM on way!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #143049 25th Sep 2012 8:19pm
Fox
Replied. Smile
Don't worry about putting what you don't want on the other forums.
Now I've taken the time to sort it out and make pictures I'll stick it on the bay of eeeee.
Post #143102 26th Sep 2012 7:50am
