![]() | Home > Off Roading & Green Laning > Waffle boards |
With every used waffle board set I can find being a million miles away I'm looking at new tracmats and wondering if I could get away with the 38mm thickness or if being a fatty the FFRR needs the 50mm ones as I'm looking at getting the 1.4m to help with the fat front over hang |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Tracmat say that the 38mm will take 2500 kg, while the 50mm will take 3000 kg. So you should be OK with the 38mm version but I went for belt & braces and got the 50mm a few years ago. |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Where are you?
Up in Warrington Fox |
Cheers Fox |
My stuff is all offroading gear in general.
Hmm a winch you say, what else would one need other than fairlead rollers to get that to fit into the L322 cradle? im guessing a drum?
It's just the motor.
cheers fox mucho appreciated |
I've run out of time tonight, it's dark and blowing a gale out there!
Fox there's no need to apologise I appreciate the effort |
Righto...
ooooo
Replied. |
