Home > Technical (L322) > Really, really hot centre console!
inkiboo
Switzerland 2007 Range Rover Vogue SE TDV8 Java Black
Is it normal for the centre console storage bin to be really quite hot?
Post #9780 21st Dec 2009 8:57am
Vogue
no Surprised
Post #9791 21st Dec 2009 12:32pm
inkiboo
Ok. Wonder what that can be then!
Post #9793 21st Dec 2009 1:15pm
Vogue
Two options imhe.
1). Transmission overheating - check oil levels and oil cooler for gear box if fitted - maybe blocked with mud if previously used off road in deep goo.
2). Heating ducts maybe displaced
3) Wink Could be on fire and smouldering away slowly Shocked
p.s. warmish is normal, really hot is not
Post #9796 21st Dec 2009 2:57pm
inkiboo
Vogue wrote:
Two options imhe.
It's only just been serviced and had an air conditioning leak fixed. Thinking it could be option 2. Add to that, the entertainment system is now dying (no audio, no sat nav) and I think the problems could be related.
Saying that, we did also go through some heavy snow so maybe it is that?
Post #9798 21st Dec 2009 3:18pm
The doc
2008 Range Rover Vogue TDV8 Java Black
Have you tried turning the rear console vents to cold?
The tubes for the rear vents make the armrest area hot if they are set to hot and cold if set to cold. '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #9892 22nd Dec 2009 11:15pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Yes, in the summer its freezing cold in there....Good for beverages....
Disconnect the button for the rears controls. The air speed diminishes and consequently also the temperature.
Post #9900 23rd Dec 2009 12:47pm
Paul J.
Re: Hot centre console ....
I had this problem. After investigation it was found that the front part of the ac unit was not 'talking' to the rear part.
Sounds like a dealer visit. Confused
Paul
Post #9986 26th Dec 2009 11:08pm
