Home > Technical (L322) > fuel burning heater
daveo
fuel burning heater
hi all i have an 04 FFRR v8 Autobigraphy, i have seen a few posts about climate fuel burning heaters, how can i tell if i have one or not, i dont have the remote control for it but was told that dosnt mean i dont have the burner. how can i tell if its fitted
thanks daveo
Post #9764 20th Dec 2009 10:56pm
The doc
2008 Range Rover Vogue TDV8 Java Black
Set the timer on the sat nav - you will soon know - I've never seen one without btw Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #9775 21st Dec 2009 7:28am
Andy
I have it in my sat nav but it blows cold air. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #9776 21st Dec 2009 8:05am
daveo
hi, yes i have it in my menu but as noddy said, mine too blows cold air, i did only have it on for about a min , may be this was not long enough..is there a sticky for testing its operation
daveo
Post #9777 21st Dec 2009 8:11am
itguy
2006 Range Rover Vogue Td6 Cairns Blue
A good test will be to switch it on manually (or via the timer) and stand outside the car. If you can hear a clicking then it should be working as this noise is the fuel pump pulsing fuel into it. Do this with the engine not running. FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9782 21st Dec 2009 9:35am
ENVOY
United Kingdom 2003 Range Rover Vogue Td6 Java Black
how do you turn it on manually Question
Post #9818 21st Dec 2009 8:54pm
daveo
hi, i was told that only diesels have them and not petrols...true or false.. and if you have it how long does it take to warm up. V8 facelift Range Rover Autobiography 22" wheels.
Post #9819 21st Dec 2009 9:01pm
ENVOY
that sounds about right about only diesels having them fitted, i have read that somewhere before im sure of it! they take about a minute to run through the start up procedure but it will take about ten to fifteen minutes to warm the water up in the engine (if the engine isnt running)
If you had one fitted you will notice that if the temp outside is less than 5 degrees and you start the engine then the FBH will start automatically to help warm up the engine quicker Thumbs Up
Post #9820 21st Dec 2009 9:09pm
itguy
The FBH was fitted to all TD6s as standard but control of it via the computer and remote fob was optional and then added later in the MYs.
Starting it manually should be available via the computer - an option somewhere like aux heating / park heating?. In the MY05 onwards cars it's called Timed Climate.
The petrol models also were available with a FBH but it was optional and not many people bought it - so it's probably unlikely you've got one.
Envoy is right, about 10 - 15 mins running to get the cabin nice and warm.
After reading RAVE, it appears that if the FBH is activated when then engine isn't running it uses diverter valves to heat the coolant just through the heater matrix and not the whole system - these then switch over to the full system when it's started from cold and under 5deg C ambient temp. FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9821 21st Dec 2009 9:16pm
The doc
You can buy timers or remote sytems on ebay that will bring it to life. Timers are around £65 and the full webasto remote system is around £175 ish
I'll take some pics of what a FBH looks like so you can see if you can spot it, no point ordering the bits if you dont have the heater Whistle '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #9823 21st Dec 2009 9:21pm
daveo
hi, if i get the option up on my nav screen,as i do would that indicate i have it.. V8 facelift Range Rover Autobiography 22" wheels.
Post #9825 21st Dec 2009 9:23pm
The doc
I had a good look but all I could see was engine - I'll look again in the morning.
Post #9831 21st Dec 2009 9:39pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
The FBH is under the battery tray - so it's invisible without dismantling stuff...
Post #9838 21st Dec 2009 10:50pm
The doc
Shows what I know Whistle '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #9839 21st Dec 2009 10:59pm
itguy
You should be able to see the exhaust of the FBH by looking down the right-hand side of the engine towards the floor. It's a metal pipe about 1" in diameter that just pokes out of the right-hand side.
My car is at the garage otherwise I'd take a pic for you to see FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9847 22nd Dec 2009 10:41am
