Home > Technical (L322) > front suspension higher than rears |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
I levelled mine out, and then dropped it 25mm. Looks a lot better and handles well
21st Aug 2012 8:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 |
was that just in standard mode,it does seems a lot.. ... - .- -.
21st Aug 2012 8:19am |
Yeah, I'm hoping that the IIDTool only tricks the ECU for the mode you're in at the time and not all modes. If it went into "motorway" mode when I'm in Germany later this year I'd be worried about a 5mm-lower-than-access-mode height at 100+ mph
21st Aug 2012 11:11am |
i think that you might have inadvertently lowered the whole lot..have a check in access to see if thats come down 25mm as well, if so then you can bet the motorway mode has as well.. ... - .- -.
21st Aug 2012 11:59am |
Well as long as I remember to change it when I go abroad I should be ok then. I keep the IIDTool in the glovebox in case I get a temptation to nip off-road anyway.
21st Aug 2012 12:18pm |
thats the beauty of this tool, so small and easy to use where ever you are.. ... - .- -.
21st Aug 2012 12:20pm |
