Home > Technical (L322) > front suspension higher than rears
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I levelled mine out, and then dropped it 25mm. Looks a lot better and handles well Smile
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #136948 21st Aug 2012 8:18am
was that just in standard mode,it does seems a lot.. ... - .- -.
Post #136949 21st Aug 2012 8:19am
TheAllSeeingPie
Yeah, I'm hoping that the IIDTool only tricks the ECU for the mode you're in at the time and not all modes. If it went into "motorway" mode when I'm in Germany later this year I'd be worried about a 5mm-lower-than-access-mode height at 100+ mph Wink
Post #136981 21st Aug 2012 11:11am
i think that you might have inadvertently lowered the whole lot..have a check in access to see if thats come down 25mm as well, if so then you can bet the motorway mode has as well.. ... - .- -.
Post #136990 21st Aug 2012 11:59am
TheAllSeeingPie
Well as long as I remember to change it when I go abroad I should be ok then. I keep the IIDTool in the glovebox in case I get a temptation to nip off-road anyway. Smile
Post #136995 21st Aug 2012 12:18pm
thats the beauty of this tool, so small and easy to use where ever you are.. ... - .- -.
Post #136997 21st Aug 2012 12:20pm
