Home > Technical (L322) > front suspension higher than rears |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35328 |
been messing with my suspension settings today and noticed that the front was 10mm higher than the back..anyone have ideas why this is ? ... - .- -.
17th Aug 2012 4:05pm |
Coz you been messing with the settings...Doh |
17th Aug 2012 4:26pm |
original settings john..... ... - .- -.
17th Aug 2012 4:27pm |
Have you tried disconnecting the battery for 20 minutes
17th Aug 2012 4:37pm |
17th Aug 2012 5:31pm |
17th Aug 2012 5:37pm |
i found this contributed by joe90 and it shows a difference of 10mm , but why?
17th Aug 2012 5:41pm |
Sounds to me like it's throwing a hissy-fit because you're thinking of selling it |
17th Aug 2012 6:00pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I guess because you may need more height/ground clearance at the front as you are more likely to approach obstacles going forwards? .
17th Aug 2012 9:00pm |
makes sense tim, also what about when you brake the front goes down and the extra 10mm accounts for this maybe.. ... - .- -.
17th Aug 2012 9:05pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Maybe its so they emulate the squat that early 2 door Classics used to get under acceleration.
18th Aug 2012 5:56am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Mine rears up like Bigfoot when pulling away. I swear it could climb over small hatchbacks in much the same way! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
20th Aug 2012 4:01pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1367 |
I love seeing RR's boot it off the line and the rear end sit down ... gives it a look that no other 4x4 has.
20th Aug 2012 7:59pm |
seems normal then, thanks all.. ... - .- -.
21st Aug 2012 8:16am |
