![]() | Home > Technical (L322) > Exhuast Gas Recycling Valve TDV8 |
It will generally make the engine better as you are not re-using dead air as it were.
I thought the TDV8 had 'self cleaning' EGR valves |
Is that the fairies that go in and clean them |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35630 ![]() ![]() |
they can probably be cleaned..joe90 cleaned his td6 valve so its possible.. ... - .- -.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
TD6 one no problem to clean out, they can get choked with carbon. Did mine before I decided to remove it. I have read reports of the ones on the Sport and Disco needing cleaning so should be a straightforward job but not done it so can't comment on whats involved. However it is probably easier to clean if you take them completley off. Mine was a blue one! |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
TDV8, TDV6, SDV6 and TD4 (Puma) valves are all self cleaning, but still do get blocked... l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
Stingclive33 Member Since: 07 Jan 2012 Location: Rye Posts: 28 ![]() ![]() ![]() |
on the cleaning angle, apart from actuall carbon build, up are EGRV'S liable to fail in any other way, dodgy electronics for example? |
its the mechanics that normally get clogged up..electrical bit should be ok.. ... - .- -.
Thanks Stan and Ivor, I always impressed by the level of knowledge and support on this great forum |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
EGR blanking kits are very common Tdi and Td5 engines, although I'm not sure how the more complex engine management and diagnostic systems would cope with them. Si. <This is my name.
WYNNS EGR DIESEL CLEANER...
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Holy thread resurrection Batman |
Does anybody know the book number of LR labour hours charged for swapping out both EGR valves? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1808 ![]() ![]() |
Book time is 2 hours for both valves...
