Home > Technical (L322) > Exhuast Gas Recycling Valve TDV8
Page 2 of 3 <123>
DavidC
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Cost for both replaced at main dealer was almost exactly £1000.
Post #311082 6th Feb 2015 9:30am
ajac8
Gazellio @ Prestige Cars wrote:
WYNNS EGR DIESEL CLEANER...
With engine fully warmed:
Open Air Filter Box and remove Air Filter
Start Car and run at idle
Spray can into Air Intake(s) at 1 second bursts max
Occasionally increase revs to 1500 rpm then let engine stabilizes back to idle before repeating
During spraying RPM will fluctuate with possible Diesel knocking
Continue 1 second bursts until Aerosol empty (may take a while)
Run at idle for 5 minutes
STOP Engine
Reconnect Filter/Parts
START ENGINE and drive 4-7 miles but DO NOT EXCEED 3000RPM
Allow engine to idle for at least 60 seconds before turning off.
This process will help clean the EGR's, Inlet Valves, MAF Sensor and whole Air Intake system.
Da Da Thumbs Up
Gaz, Would this be applicable to the 4.4 TDV8 as well as the 3.6?
cheers 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #316742 7th Mar 2015 6:43pm
I guess so yes but having now seen an EGR valve post terraclean I think its probably better to go straight for EGR replacement. They are better but far from clean of carbon deposits.
Post #316758 7th Mar 2015 8:30pm
cheers
What are the issues with your EGR's ajac?
Post #316780 7th Mar 2015 11:06pm
ajac8
none my friend - just thinking pre-emptive. seems a cheap thing to do but sometimes doing something you think is simple is not alway the case.
suppose its the same as redex additives - you just need someone to say - yep its ok to do that!. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #316810 8th Mar 2015 1:08am
Ahh i see Thumbs Up
The 4.4 does NOT suffer with the EGR issues the 3.6 did though Surprised
So, i'd leave well alone on the later cars my friend Thumbs Up
Post #316811 8th Mar 2015 1:11am
ajac8
Thumbs Up will do. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #316840 8th Mar 2015 10:44am
Post #316874 8th Mar 2015 12:42pm
rar110
Holy crap, that's about $2500 in OZ.
Are there any preventative measures? ______________________________
Post #317255 10th Mar 2015 11:47am
Praying to the RR gods! Giving to charity, being polite to vicars etc etc etc
No not really! Fact of life I'm afraid sir Rolling Eyes
Post #317267 10th Mar 2015 12:57pm
Quote:
Giving to charity the Poor KurtVerbose Benevolent Society
This will definitely save your EGR! Thumbs Up
Post #317284 10th Mar 2015 1:36pm
RRG
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
I'm a bit new to the subject of EGR but am trying to read up as I investigate the TDV8 turbo failure subject...
...so a couple of quick questions please:
1. what are the symptoms of EGR failure? Can failure damage anything else in the engine?
2. Can the EGRs be removed and blanked on the TDV8? Anyone done it?
3. If removed, would the car struggle to meet UK MOT emissions tests?
thanks, apologies if this is old ground...
best
RRG
Post #317302 10th Mar 2015 3:09pm
DavidC
I can only comment about the failure to my car - the EGR valves used to make a squeaking noise after switch off (the indy told me that was the source of the squeak) - I thought this was standard, however the new valves do not make this noise, so perhaps that was an indication of failure.
I had no smoke from exhaust, no other symptoms, first thing I knew about it was a warning on the dash. Codes read and under advice from the Forum I took directly to dealer who diagnosed both sides needed replacement.
I used Redex regularly and at services the indy used Forte system cleaner - neither seems to have helped.
Post #317311 10th Mar 2015 3:38pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
Wynns EGR Cleaner on TDV8 4.4
So having read the thread, and especially Gaz's step by step guide, am I right in thinking that it is best to leave the TDV8 4.4 alone, unless there are symptoms of EGR problems, rather than doing this as a pre-emptive measure? Even then, as the TDV8 has two air boxes/ filters, would it be necessary to remove both to squirt the stuff in both sides? 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #341634 10th Aug 2015 1:35pm
Zirconblue
the EGR cleaner spray seemed to make a difference on my Jaguar. I can't see it curing a blocked one, but giving it a dose of it every service should help stop the gunk building up.(redex and other products that go in the fuel wont clean the air inlet)
It's basically just air intake cleaner, like you'd use on a carb. It breaks down the black snot that builds up in there when the carbon mixes with crank case vapours. On most turbo diesel cars you'll find half the inject tract clogged with it.
One problem the Jaguars used to suffer was the gasses leaking into the electronics on the EGR valve and killing it that way. On the subject of electronic EGR valves, it's normally not possible to completely blank them off without modifying the engine management software. As the computer detects the plate as a blockage and puts the check engine lamp on, you still get the benefits of the blank, but the car wont pass an MOT with the engine light on. So you have to tell the computer to ignore the EGR fault.
Post #341642 10th Aug 2015 2:16pm
Page 2 of 3 <123>
