Home > Technical (L322) > Exhuast Gas Recycling Valve TDV8
Page 1 of 3 123>
Stingclive33
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Following the appearance of an amber engine warning light and a trip to see FFRR member Piecost who very kindly used his Hawkeye box of tricks to tell me it related to the Exhaust Gas Recycling Valves. I took a futher trip to my local mechanic who confirmed the diagnosis and informed me that there are two EGRV'S and they cost £129 plus VAT plus fitting. He also said that the problem probably relates to carbon buid up and that a careful cleaning with suitable brushes and carb cleaner would do the trick negating the new EGRV'S.
What do you guys think?
I notice that you can buy a blanking kit that allows the the removal of the EGRV'S from the TDV6 only though, even with the claim that it improves performance.
Post #131798 18th Jul 2012 1:00pm
It will generally make the engine better as you are not re-using dead air as it were.
Phone around and see if you can get the blanking plates, if you can stick them on instead as a less lessy job to do.
Cleaning them out will be a PITA and then you'll want to clean the stuff they plug into as that will no doubt be caked as well... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #131801 18th Jul 2012 1:10pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I thought the TDV8 had 'self cleaning' EGR valves Neutral Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #131804 18th Jul 2012 1:14pm
Is that the fairies that go in and clean them Wink
Maybe they have some kind of fresh air inlet to help clean them out but EGR's will always end up caking in orrible stuff unless they get a flush through of eolys type fluid... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #131811 18th Jul 2012 1:31pm
they can probably be cleaned..joe90 cleaned his td6 valve so its possible.. ... - .- -.
Post #131814 18th Jul 2012 1:52pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
TD6 one no problem to clean out, they can get choked with carbon. Did mine before I decided to remove it. I have read reports of the ones on the Sport and Disco needing cleaning so should be a straightforward job but not done it so can't comment on whats involved. However it is probably easier to clean if you take them completley off. Mine was a blue one! Smile
Post #131825 18th Jul 2012 2:34pm
verydisco
TDV8, TDV6, SDV6 and TD4 (Puma) valves are all self cleaning, but still do get blocked... l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #131827 18th Jul 2012 2:36pm
Stingclive33
on the cleaning angle, apart from actuall carbon build, up are EGRV'S liable to fail in any other way, dodgy electronics for example?
Post #131934 19th Jul 2012 8:08am
its the mechanics that normally get clogged up..electrical bit should be ok.. ... - .- -.
Post #131938 19th Jul 2012 8:16am
Stingclive33
Thanks Stan and Ivor, I always impressed by the level of knowledge and support on this great forum
Post #132101 20th Jul 2012 6:27am
EGR blanking kits are very common Tdi and Td5 engines, although I'm not sure how the more complex engine management and diagnostic systems would cope with them. Si. <This is my name.
Post #132103 20th Jul 2012 6:59am
WYNNS EGR DIESEL CLEANER...
With engine fully warmed:
Open Air Filter Box and remove Air Filter
Start Car and run at idle
Spray can into Air Intake(s) at 1 second bursts max
Occasionally increase revs to 1500 rpm then let engine stabilizes back to idle before repeating
During spraying RPM will fluctuate with possible Diesel knocking
Continue 1 second bursts until Aerosol empty (may take a while)
Run at idle for 5 minutes
STOP Engine
Reconnect Filter/Parts
START ENGINE and drive 4-7 miles but DO NOT EXCEED 3000RPM
Allow engine to idle for at least 60 seconds before turning off.
This process will help clean the EGR's, Inlet Valves, MAF Sensor and whole Air Intake system.
Da Da Thumbs Up
Post #309317 30th Jan 2015 6:51pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Holy thread resurrection Batman Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #309328 30th Jan 2015 7:47pm
Does anybody know the book number of LR labour hours charged for swapping out both EGR valves?
Post #310982 5th Feb 2015 7:51pm
Mikey
Book time is 2 hours for both valves...
Though in reality, 4 seems to ring a bell, though that may have been an RRS Embarassed
Post #311002 5th Feb 2015 8:31pm
Page 1 of 3 123>
