![]() | Home > Technical (L322) > Exhuast Gas Recycling Valve TDV8 |
DavidC Member Since: 08 Oct 2012 Location: Beds Posts: 66 ![]() ![]() ![]() |
Cost for both replaced at main dealer was almost exactly �1000. |
I guess so yes but having now seen an EGR valve post terraclean I think its probably better to go straight for EGR replacement. They are better but far from clean of carbon deposits. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
What are the issues with your EGR's ajac? |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
none my friend - just thinking pre-emptive. seems a cheap thing to do but sometimes doing something you think is simple is not alway the case.
Ahh i see |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Holy crap, that's about $2500 in OZ. Are there any preventative measures? ______________________________ Vogue tdv8 08MY poverty pack - wow |
Praying to the RR gods! Giving to charity, being polite to vicars etc etc etc
This will definitely save your EGR! ![]() |
RRG Member Since: 08 Jan 2010 Location: London Posts: 124 ![]() ![]() ![]() |
I'm a bit new to the subject of EGR but am trying to read up as I investigate the TDV8 turbo failure subject...
I can only comment about the failure to my car - the EGR valves used to make a squeaking noise after switch off (the indy told me that was the source of the squeak) - I thought this was standard, however the new valves do not make this noise, so perhaps that was an indication of failure.
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
So having read the thread, and especially Gaz's step by step guide, am I right in thinking that it is best to leave the TDV8 4.4 alone, unless there are symptoms of EGR problems, rather than doing this as a pre-emptive measure? Even then, as the TDV8 has two air boxes/ filters, would it be necessary to remove both to squirt the stuff in both sides? 2011 Vogue TDV8 4.4
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
the EGR cleaner spray seemed to make a difference on my Jaguar. I can't see it curing a blocked one, but giving it a dose of it every service should help stop the gunk building up.(redex and other products that go in the fuel wont clean the air inlet)
