![]() | Home > Maintenance & Mods (L322) > cleaning Satnav screen |
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 ![]() ![]() ![]() |
That's quite possibly what they used on mine, either way, they cleaned it to my satisfaction |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Ajay, did you use a standard baby wipe and how long did you wipe the screen for, and in what motion, circular or side to side?
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Which particular baby wipe dic you use???? |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Guys, as far as I can rememeber I used just a standard Johnson's Baby Wipe in the pink packet. |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 507 ![]() ![]() ![]() |
now that the coating has been removed - does it make any difference to the dual view? MY11 Vogue 4.4 TDV8 - "African Queen" |
None what so ever - The dual view screen is based on the pixels in the screen and has nothing to do with the coating |
that's good news. I was worried the fingerprints that weren't clearing were more due to small scratches that won't come out so hopefully this isn't the case.
BMW do the same on their screens, my X6 of a few years back has the same problem only far worse, the screen was a mess because the coating was marked.
tobylo Member Since: 26 Jul 2012 Location: Dublin Posts: 52 ![]() ![]() ![]() |
i use the cloth that came with my sunglasses (micro fibre) and a pc screen cleaner spray |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
I can see when the screen is turned off slight abrasion marks in areas of higher use. I think my wife's finger nails are causing the scratches. I have fitted a cut down iPad screen protector, not got the right measurements and it was hard to get it neat. I need to get the dimensions and do it on a guillotine at work. From what I can tell today, the protector disguises the existing scratches, works ok too, offers longer term protection from further damage too. Surprised no one is selling them on eBay as would fit other LR models too. 2012 4.4TDV8 VSE
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 190 ![]() ![]() |
I cleaned mine with the lemon scented hand wipe that got with a macdonalds take away, been clean ever since. |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Get some "muc off" screen cleaner, brilliant stuff. Squirt it on a microfibre cloth then wipe away. All marks disappear and looks like new |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
I used HQ screen cleaner and a microfibre cloth. That removed the oily marks, but there were still small scratches from my fingers on the screen. I followed Cam-Tech Craig's advice and cut an iPad cover to size and put that on top of the screen. Looks better, scratching issue solved. Only Range Rovers since 1988 |
Binks Member Since: 03 Mar 2012 Location: Bristol Posts: 17 ![]() ![]() ![]() |
Brilliant. Cleaned with baby wipes, applying sufficient pressure and perfect result. Completely clear. Used a bic biro top to apply pressure under the wipe as your finger gets sore after a while! And you can get into the edges and corners with it too. Very pleased with this - thanks guys! TDV8 3.6 2010 Santorini Black / Jet Interior
