![]() | Home > In Car Electronics (L322) > 2003 ffrr digital tv hybrid tuner from a bmw |
tony1kenobee Member Since: 07 Jul 2012 Location: SOUTHAMPTON Posts: 145 ![]() ![]() ![]() |
hi all, am looking to upgrade my analogue tv tuner to digital. i have a non touch screen head unit with a harman kardon logic 7 system in situ.rr is 4.4 v8 l322 autobiography o3 plate running on lpg.any help or knowledge of where i can get one would be greatly appreciated.regards in advance tony |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
I've just fitted a digital freeview box from THIS GUY.
hi thanks for your response.firstly im not that technically gifted,secondly how long would it take to fit and finally how good is the reception.regards in advance.tony |
There's not really anything technical about it.
I found an unused plug, maybe for the DVD but I'm not sure, but it's black with a white locking arm on it and take it's feed from a large white connection (see photo below). I took the feed from the Purple/White wire from this plug, cut it and used a red crimp connector. Sadly it's all tied up again and I didn't want to unravel it all again. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7879 ![]() ![]() ![]() |
The black connector looks like the prewire for the phone ................ 2011 Range Rover Vogue SE 4.4 TDV8
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Thanks mate-I appreciate that! very helpful! , so it's just the earth and pos you have to worry about, all the other connections are plug and play? Where did you put the remote eye? 2003 Vogue 4.4 V8 Java Black |
Yep, the other connections are on the supplied loom, one into the original TV tuner, and three audio style connections into the back of the digibox.
Budgie, your car will be pre-wired for phone.
Thanks Mark.
If you search for BMW ULF on the forum, or from Google, there is quite a bit of info.
