Home > In Car Electronics (L322) > 2003 ffrr digital tv hybrid tuner from a bmw
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
hi all, am looking to upgrade my analogue tv tuner to digital. i have a non touch screen head unit with a harman kardon logic 7 system in situ.rr is 4.4 v8 l322 autobiography o3 plate running on lpg.any help or knowledge of where i can get one would be greatly appreciated.regards in advance tony
Post #131010 14th Jul 2012 6:48am
Budgie
I've just fitted a digital freeview box from THIS GUY.
Easy to install as you only need to find an ignition fed positive and an earth, all the other connection are in a loom that's supplied.
It keeps the original tuner and just plugs in to it, then you use the AV function on the dash TV. It comes with a remote, is easy to tune and gives a good picture.
I went for this as I couldn't find an option that you get with the later touchscreen where you can just swap out the tuner. Wink
Post #131025 14th Jul 2012 9:51am
tony1kenobee
freeview
hi thanks for your response.firstly im not that technically gifted,secondly how long would it take to fit and finally how good is the reception.regards in advance.tony
Post #131030 14th Jul 2012 10:31am
Budgie
There's not really anything technical about it.
You have a red & a black wire from the fused power connection to the unit and a red & a black wire to the booster of the antenna. Join these together and find a suitable positive connection that goes off with the ignition. The earth (black wires) are easy as there's a bank of earths above the satnav disc drive in the rear anyway. Wink
If you're worried about the wiring then let me know if you get one and I'll take some photos and do "How too" for you.
I had it wired and working in about 30 minutes and then did some testing for the best place to put the antenna.
The reception is as good as your home TV on a set-top aerial, sometimes better, sometimes worse. I can get ITV1 and Channel 4 from the front of the house but not BBC1 or BBC2. Move up the road 100 yds and all channels are perfect.
As for tuning, is has an "Area Tune" facility that goes through the frequencies automatically, the same as a normal freeview TV does, and loads the TV and audio channels for you. You can also assign you favorites and move the channels around so you get them in the order you want (all the shopping channels when the wife won't find them Laughing )
If reception is a issue then there's an upgraded version that has a twin tuner & twin aerials, but it's twin the price. Wink
Post #131088 14th Jul 2012 7:24pm
Tuts
Budgie, which wires did you tap into for the positive feed? Can you put a photo on? Did you solder or scotch lock the new wires in? Cheers 2003 Vogue 4.4 V8 Java Black
Post #131090 14th Jul 2012 8:01pm
Budgie
I found an unused plug, maybe for the DVD but I'm not sure, but it's black with a white locking arm on it and take it's feed from a large white connection (see photo below). I took the feed from the Purple/White wire from this plug, cut it and used a red crimp connector. Sadly it's all tied up again and I didn't want to unravel it all again. Wink
This second photo is of the digibox attached to the bottom of the Satnav and it shows the earth connections.
Post #131106 14th Jul 2012 9:21pm
mjdronfield
The black connector looks like the prewire for the phone ................ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #131110 14th Jul 2012 9:36pm
Budgie
It could be as I don't have the phone installed.
Post #131114 14th Jul 2012 9:48pm
Tuts
Thanks mate-I appreciate that! very helpful! , so it's just the earth and pos you have to worry about, all the other connections are plug and play? Where did you put the remote eye? 2003 Vogue 4.4 V8 Java Black
Post #131116 14th Jul 2012 9:56pm
Budgie
Yep, the other connections are on the supplied loom, one into the original TV tuner, and three audio style connections into the back of the digibox.
The remote eye I fed up the inside of the C-pillar with the aerial cable. The aerial is stick to the top of the passenger side rear window with the cable running into the rooflining and the eye pokes out of the top of the C-pillar trim.
You can either point the remote backwards or aim at the rear view mirror. Wink
Post #131167 15th Jul 2012 11:04am
mjdronfield
Budgie, your car will be pre-wired for phone.
The 54 pin black connector goes to the telephone module.
Also in the pic you can see a thicker wire with a purple and black connector on the end, that is for the bluetooth aerial.
I retrofitted the phone to mine, and is touched on in the thread below ;
http://www.fullfatrr.com/forum/topic11997....+bluetooth
You will also have the microphone wiring already there behind the trim near the sunroof switch......
I know its a bit off topic, but thought you'd like to know what the connector was for that you used.
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #131170 15th Jul 2012 11:11am
Budgie
Thanks Mark.
I'm in the throws of installing a Parrot CK3100 as I'd bought it for the Vectra VXR that I had before this one but if I can get a ULF module then that will save some effort in running an extension loom to the front of the car. Very Happy
I take it I'm looking for something like THIS?
Post #131176 15th Jul 2012 11:31am
mjdronfield
If you search for BMW ULF on the forum, or from Google, there is quite a bit of info.
http://www.bimmernav.com/ulfchanges.html
http://www.fullfatrr.com/forum/topic9793.html
The part number on that ebay item is not on the list, but the list may not be exhaustive.....
So we don't go off topic on a thread about TV tuners PM me if you want to know more, or start another thread - may be better......
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #131180 15th Jul 2012 12:19pm
