![]() | Home > Wheels & Tyres > Advice please on wheel change |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
You should have 255/60/18 as standard
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 ![]() ![]() ![]() |
Hi thanks for the speedy response, would you go for the 19, 20 or stick with the 18 inch. Any ideas why I would have 265 tyres on my car and not the standard 255?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
i had those on mine elena, i think LR brought a cheap batch of them during 2005/2006 ...
Hi Stan thanks for the advice, watching some 19 inch ones on eBay. Does the spare have to be the same size wheel etc.
the spare doesnt have to be the same but its desirable for it to be... ... - .- -.
19s are a good upgrade for the TD6 without making for too harsh a ride, also a bit less tyrewall reduces the cornering roll effect
Hi, thanks for your advice just bought a set of 19 inch wheels with tyres. Do I need to have the suspension settings set to anything other than normal before changing the wheels please, may be a silly question but thought I should ask it, cheers. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Hi Elena
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7977 ![]() ![]() ![]() |
enumbers Member Since: 12 Dec 2011 Location: South east Posts: 26 ![]() ![]() ![]() |
Stan why is there a vibration issue on the td6 with the 20s on 2004 td6 Adriatic Blue |
Don't know the reason for the vibration with 20s on the TD6, but LR do not recommend fitting them. |
@enumbers, its the change in inertia and stiffness of the wheels allows a torsional resonance through the driveline from the engine firing pulses... ... - .- -.
Cheers for the explanation its crazy that the reduction in flex in the tyre wall would cause a noticeable effect 2004 td6 Adriatic Blue |
