Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 5 of 49 <123 456 ... 474849>
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Guys!
Thanks Gary! I’ve been more a reader than a poster on FFRR for the past few years. Since Steve is enjoying some time off, it’s the right time to jump in.
Colin: My pleasure!
Well, we’ve just tried activating / deactivating the 3 turn flash on the CCF of our Range Rover 2007 and unfortunately, it does not work. We believe this feature is activated / deactivated the same way the low temp warning bong is, that is directly in the IPC. The low temps warning is one feature we definitely want to be able to change since we benefit from the 4 seasons here and this bong makes us think about other more serious bongs and lights not so glittering with joy. Rest assured that we will work to find the solution for those features.
MPx: Unfortunately, it cannot be done this way. What we will do is add it in the live value function which will be equivalent. This way you will be able to see it on request.
Cheers!
Post #132048 19th Jul 2012 8:00pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
My IID Tol just arrived. Got it updated and been out to play Very Happy
Gave me more detailed fault codes than my blackbox faultmate (eg it identified my EGR fault which faultmate did not).
Really easy to use.
Disabled "key bong"
Enabled automatic lock when moving (great safety feature IMO to stop theft from car at lights etc)
Enabled sat nav on the move (but forgot to test it's working)
Enabled chirp on lock
Questions;
1 - I enabled auto re-lock think this will be good for those senior moments (Did i lock the car????) But worried now - if i leave key in the boot and forget whilst i'm washing the car - will it lock my key in??
EDIT: the auto re-lock is when you unlock car then do not open any doors. Embarassed Duh! - So not possible to lock the keys or the kids in the car
2 - Activated follow-me-hoe for main beam and reverse lights - but did not seem to work?! I take it this should turn on the main beam and reverse lights when i lock the car? Does it matter what setting the light switch in the car is at? (Usually auto)
Overall great tool and soooo satisfying to have control over all these config options..
Post #132760 24th Jul 2012 10:17pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Follow me home usually requires a flash of the main beams to activate the timer
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #132761 24th Jul 2012 10:21pm
Aurrian
Ah - that makes sense thanks. Wife's got an audi and they just come on automatically so was expecting that.
Anyone got any ideas about the auto-relock?
Post #132764 24th Jul 2012 10:31pm
PatGAPInnov
Site Sponsor
Hi Guys
Thank you all for the positive feedback, makes it all worth it!
Now for the latest news:
After Mike (MPx) requested it, we thought it might be useful to others also. We’ve added the ability to see Service Announcement values in the live values function for 2006-2009 Range Rovers. It is also available on the Discoery 3/LR3 and RRS. For the Range Rover, it shows:
-If the Service Announcement is activated
-How many kilometers are left until your next service is due
-The service period (almost all vehicles are set at 12 000 km)
-How many days have passed since the last service interval reset was performed.
The IPC does not base itself directly on a distance left but rather on how many liters of gasoline the vehicle has consumed since the last service interval reset was performed. The IPC assumes an average consumption of 16.8 L/100 km and give you the approx distance left. We do exactly the same in the IIDTool. The real distance until the next service reminder will therefore vary depending on your average fuel consumption.
We’ve also added the possibility of activating/deactivating the Cold and Hot Lights Monitoring features in the car configuration menu (good idea Craig!). This should prevent flashing of LED’s and warning messages on converted vehicles. For more details, please consult the functionality table of the website.
http://www.gap-diagnostic.com/products/iidtool.html
We are also working on improving the updater software. Soon, it will be able to update itself on the press of a button. This way, users won’t need to uninstall, download and install the updater when a new firmware version is available.
Cheers!
Post #133269 27th Jul 2012 5:00pm
Aurrian
The feedback is justified.
Just yesterday i emailed Patrick about HDC and suspension warnings i was getting. He offered to help, and within a few hours i had emailed him the error codes and he had replied with explanation and even offered a couple of probable causes for me to investigate.
That's some service!
Thanks again Thumbs Up
Post #133280 27th Jul 2012 6:19pm
Cheers!
Thank you Patrick Thumbs Up Im a happy chappy now Bow down Thanks again...
Craig Thumbs Up
Post #133317 28th Jul 2012 12:13am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
What is hot and cold monitoring ? I presume it's something to do with checking for a malfunctioning bulb, but not sure of the difference between the two.....
Also, now that the functionality has been introduced, do i need to uninstall and then reinstall my current V2.17 ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #133331 28th Jul 2012 8:15am
MPx wrote:
SteveMFr wrote:
Hi MPx,
By performing a SIR (service interval reset) on your vehicle with an IIDTool, this function should be reinstated.
Thanks for this Steve - hope your hols are good!
Patrick, my take on Steve's answer is that by doing a "reset" it will (or at least might) switch the function back on. I'm guessing that if it does work, the car would then display 15000 miles next time I switch on as the start of the next service countdown. I was hoping for something closer to an on/off flag somewhere, and if switched on would actually show the current status (eg 1250 miles to go to next service or whatever). So is it the case that there's nowhere to look to see the current status albeit not currently dashboard displayed???
Check your service book then reset?
Craig Thumbs Up
Post #133338 28th Jul 2012 9:24am
un-install the gap software from the 'program' feature in your computers control panel, then re-install as a new program... ... - .- -.
Post #133343 28th Jul 2012 9:42am
Flashman
Hot monitoring is when the LCM checks the bulbs when the lights are switched on.
Cold monitoring is when the LCM checks the bulbs when the lights are switched off.
I guess you will still need some resistors to stop the indicators flashing double speed, or would turning off the checking solve the issues of adding the LED lights in a conversion? Tom
Current Drive
Previous Drives
Post #133354 28th Jul 2012 10:30am
Craig Thumbs Up
Eerrr yeah thanks Craig. Confused Last service last August at 52k. Now at 64.5k.....so the answer is???
Anyway no worries cos Patrick and co have done a fantastic job of adding the feature so I know that the distance to go until the next service is due is about 700miles. Just as you thought? Laughing
It really has been an impressive response - not just in engaging with the request but also in the speed and helpful manner in which they've done it. Exemplary guys. Many thanks. Mike - MPx
Post #133382 28th Jul 2012 5:56pm
Craig Thumbs Up
Well the obvious answer would be service due in August as its a yearly service if adequate mileage has not been achieved... Whistle
Post #133395 28th Jul 2012 9:23pm
CG-SC
I was driving up to the Isle of Skye yesterday with my family for our summer holiday, the SC was full laden, 4 bikes on the back and was effortless, then the EML light came on but still driving fine...
So I pulled over, plugged the IID in and read the fault code - P0140, Bank 1 Sensor 2 no circuit.....cleared the fault fired her back up and drove the rest of the way with no issues or reoccurence of the light - any ideas ?
So handy having the IID Tool Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #133406 29th Jul 2012 8:29am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I think that is an O2 sensor. Won't do any harm in driving with that fault, enjoy your holiday!
Post #133410 29th Jul 2012 9:17am
