Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
Will this unit enable the park heat function ? |
23rd Sep 2012 2:39pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
if you have the actual fbh , then yes.. ... - .- -.
23rd Sep 2012 2:49pm |
it'll be best to wait for steve/pat to answer this one...can you update your car profile so they/we know what range you have .. ... - .- -.
23rd Sep 2012 3:13pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
You can switch it on and off using the tool. |
23rd Sep 2012 3:57pm |
Exactly. Thanks, Paul. The instrument cluster will need a reboot to show the change in the timed climate menu. Earlier cars could do a 'reset' via the 'secret menu' in th cluster (google), but it is just as easy to do a short batt disconnect (follow RR battery disconnect / reconnect procedures!). RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
24th Sep 2012 9:11am |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 |
Hi Guys
25th Sep 2012 4:10pm |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
Why does FMH not work for me? I have FMH enabled using fog lights and position lights, with a 40 second delay (which I presume is the length of time the lights stay on). But the lights never come on. I keep the light switch on the dash set to auto - does that have anything to do with it?
25th Sep 2012 6:11pm |
do you 'flash' the main beams before you leave the range... ... - .- -.
25th Sep 2012 6:13pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
my lights have to be on when i switch the car off,then when i switch of the lights they stay on for around 40s even after locking the car.
25th Sep 2012 6:58pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
05 onwards you need to turn off engine then flash your main beam to turn on FMH
25th Sep 2012 7:29pm |
Oh, I didn't know about having to flash main beam! Thanks for the heads up - I'll try that later. |
26th Sep 2012 9:02am |
Where is the best place to purchase this unit considering daveo troubles ? |
27th Sep 2012 4:24pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 590 |
Got mine from LRPARTS online quickly and for a good price. Others have done better still. Check out this thread page 11 on...
27th Sep 2012 5:15pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
Got mine through Len - salop4x4@gmail.com Very easy to deal with, and very promp in replying to emails, and posting unit out. Good price too - under half what Britpart here in Aus wanted for it. |
1st Oct 2012 5:21am |
