Home > Technical (L322) > daytime LED running lights |
andrewcooke1720 Member Since: 13 Feb 2011 Location: Co Kerry Posts: 28 |
where is the best place to pick up the positive feed to the daytime lights when the engine is turned on and running, the alternator? have found two skinny wires that go to 12V with the key turned but don't want to hack in and blow an ecu ...... Any suggestions or other locations i should consider? |
24th Jun 2012 5:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
http://www.fullfatrr.com/forum/topic11078.html ... - .- -.
24th Jun 2012 5:08pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
And here:
24th Jun 2012 5:16pm |
problem solved on eBay, switch purchased that operates when the battery voltage exceeds 13V and turns the lights on and switches them off when the side lights are switched on. happy days. |
25th Jun 2012 10:17am |
25th Jun 2012 10:25am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
I bought one of the voltage sensing DRL relays off the bay and it dont work So just connected it to an ignition switched feed. Now just waiting for the replacement LED halo to replace the one I broke fitting,
25th Jun 2012 11:09am |
That's a nice little addition with the voltage checker. Can you link to the product?
25th Jun 2012 11:11am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
you forgot to mention all the Chav bling Joe that takes a lot of power too Present :2008 TDV8 HSE
25th Jun 2012 12:10pm |
