Home > Technical (L322) > Front wipers don't park at bottom of screen |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
I had exactly the same problem (which cured itself on a couple of occasions) but then a few weeks later my wipers decided to just stop whenever they felt like it. I would definitely recommend that you try replacing the £6 relay first before moving on to the more expensive stuff.
22nd Jun 2012 8:08pm |
993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58 |
Thanks phil for your reply I'm going to try that relay al get one ordered on Monday,do u think the relay would stop the wipers parking at the bottom of the screen ? Cheers paul Range rover hse
23rd Jun 2012 9:10pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
How did you fix this, I have the same issue? |
23rd Mar 2013 9:41am |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
Unfortunately I think your wiper motor is on the way out.
23rd Mar 2013 9:52am |
Hmmm shame ..... Still under warranty tho.
23rd Mar 2013 9:57am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
try turning off the ignition when the wipers are in the park position.. ... - .- -.
23rd Mar 2013 9:59am |
Sorted - checked under the bonnet and you can see the motor and linkage quite easily behind the bulkhead on the drivers side.
23rd Mar 2013 10:32am |
