Home > Technical (L322) > Front wipers don't park at bottom of screen
993porky
England 2004 Range Rover HSE Td6 Java Black
Hi everyone was driving the other day in rain and wipers front stopped working for spilt second then started working again however when I got home and switched wipers off they parked in the uppermost position on drivers side of windscreen, I've been told this is a common fault and it is actually the wiper motor knackered as it has a sensor built in for the park position of wipers at the bottom of screen. The wipers still work however just do not stop in correct position at bottom of screen Big Cry
I'm sure someone on here had similar problem before and got fixed at the dealer but was only a £20 fix so would that mean it is only needing plugged in to diagnostic computer to sort this problem,as it seems a bit expensive to have to replace wiper motor, any advice would be appreciated cheers Paul Big Cry Range rover hse
Java black
Post #127240 22nd Jun 2012 8:45pm
RRPhil
I had exactly the same problem (which cured itself on a couple of occasions) but then a few weeks later my wipers decided to just stop whenever they felt like it. I would definitely recommend that you try replacing the £6 relay first before moving on to the more expensive stuff.
http://www.fullfatrr.com/forum/topic11626.html
Phil
Post #127243 22nd Jun 2012 9:08pm
993porky
Thanks phil for your reply I'm going to try that relay al get one ordered on Monday,do u think the relay would stop the wipers parking at the bottom of the screen ? Cheers paul Range rover hse
Java black
Post #127336 23rd Jun 2012 10:10pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
How did you fix this, I have the same issue?
Post #179268 23rd Mar 2013 10:41am
Charmer
Unfortunately I think your wiper motor is on the way out.
I had the same issue (albeit with a Mercedes). It ended up just being wear and tear on the internals of the motor. When I took the old motor out to see if it could be repaired there were loads of metal shavings where the moving parts had worn away.
On mine they had worn away so much that there were smooth parts where they should have been metal, so the system no longer stopped a cycle at the correct point.
Crying or Very sad
Post #179273 23rd Mar 2013 10:52am
Katash
Hmmm shame ..... Still under warranty tho.
Wipers stop in same place each time just at 12 o'clock
Post #179275 23rd Mar 2013 10:57am
try turning off the ignition when the wipers are in the park position.. ... - .- -.
Post #179276 23rd Mar 2013 10:59am
Katash
Sorted - checked under the bonnet and you can see the motor and linkage quite easily behind the bulkhead on the drivers side.
Loosened the (13mm I think although I used grips) nut from the motor shaft, cycled the wipers which makes the motor stop in the home position then manually moved wiper linkage to home position and tightened nut back up.
Thinking about it yesterday I put new blades on so they may be a bit harder to drive and the nut on the shaft was quite loose - add that to the fact I cleared 1-2" of snow off the screen using the wipers this morning too so I suspect it has just slipped, motor operation seems perfectly smooth and stops in the same place each time.
Post #179285 23rd Mar 2013 11:32am
