Home > In Car Electronics (L322) > dab ? |
Oh I wasn't doubting you hadn't tried Bellini
15th Jun 2012 5:05pm |
jmlello Member Since: 21 Oct 2014 Location: Levanger Posts: 3 |
Hi,
8th Mar 2015 10:06pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
That's DVB, which is digital TV, not DAB.
8th Mar 2015 10:10pm |
What is the difference between DVB and DAB? |
8th Mar 2015 10:39pm |
http://www.toytowngermany.com/lofi/index.php/t14960.html Got - 2017 SDV8 Autobiography in Loire Blue
8th Mar 2015 11:30pm |
Chillb Member Since: 25 Jul 2012 Location: Portsmouth Posts: 142 |
Was given a new Discovery Sport as a loaner, very nice but does not feel like a Discovery. Really like the DAB, one station across 120 miles of travel today, excellent. Is there any solution to being able to get DAB on an 08 FFRR. Porsche 993 Targa, Buick Skylark Convertable 1968 |
15th May 2015 6:36pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
The last Jaguar X-Types came with DAB as standard. They use the same MOST optic network and the touch screens which are an even older denso design to the FFRR (similar software) support it.
15th May 2015 8:53pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
please do try and if it works i'll be one of the first to follow in your footsteps.. ... - .- -.
15th May 2015 9:13pm |
I'll add it to the list of things to do. Might be a while though. |
16th May 2015 3:20pm |
After me Stan me old cocker
17th May 2015 7:11pm |
I'd be very surprised if the DAB unit would be "recognised" by the JLR system. I retrofitted a DAB tuner to my E60 5 series, which was an official option and it took several attempts by the garage to get it coded in.
17th May 2015 7:46pm |
No i have my doubts too, the X-type uses a slightly earlier version of the JLR system (the X-type was running MOST in 2001, it was the first JLR product to do so) they didn't change the main hardware for the 2008MY. There might have been a software update, which could be the stumbling block on the Range Rover. On the Jaguar Xtype, X150 (XK) and S type the main stumbling block is installing an aerial, but it might be worth a try. If i can find the parts cheaply enough. |
17th May 2015 8:11pm |
The other option to enable you to get the stations, certainly ones you like consistently across the UK are these after market ones that you tune in through your FM. Any decent discreet ones that anyone has tried and could recommend. You could mount out of sight tuned to the station you like and leave it. Porsche 993 Targa, Buick Skylark Convertable 1968 |
17th May 2015 8:50pm |
^ that's well documented on here - http://www.fullfatrr.com/forum/topic17064.html?highlight=dab. Mine (and a few others) like the Alpine EZ-DAB, which can connect via the AUX input and also can control iDevices. Got - 2017 SDV8 Autobiography in Loire Blue
17th May 2015 10:10pm |
