Home > In Car Electronics (L322) > dab ?
Page 3 of 4 <1234>
Oh I wasn't doubting you hadn't tried Bellini Smile
Just think that for touchscreen ones there must be something. Like in sure the cd changer could Be swapped for an mp3 hdd type unit Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #126378 15th Jun 2012 5:05pm
gabbo
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
The alpine unit looks like my Pure 300di works well and better reception than in the wife's OE in her touareg
I was thinking about swapping it into the SC as a short term measure but I've seen something on the bay of fleas which claims to give freeview and has option for DAB & a further option for hidden aerials 07MY SC VSE (on its way)
The list of previous cars is long & some are boring there has been two RRC's and a very pimped hilux
Post #129766 6th Jul 2012 8:49pm
jmlello
Norway 2002 Range Rover Vogue Td6 Santorini Black
Anyone tried this one for DAB radio?
Hi,
Im looking for an integrated solution for DAB in my RR 2002.
Have anyone tried this one?:
http://www.carphonics.co.uk/digitaltv.htm
-John
Post #317019 8th Mar 2015 10:06pm
That's DVB, which is digital TV, not DAB.
DVB can receive radio, but it's not DAB. Got - 2017 SDV8 Autobiography in Loire Blue
Post #317020 8th Mar 2015 10:10pm
jmlello
What is the difference between DVB and DAB?
Post #317025 8th Mar 2015 10:39pm
http://www.toytowngermany.com/lofi/index.php/t14960.html Got - 2017 SDV8 Autobiography in Loire Blue
Post #317035 8th Mar 2015 11:30pm
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Was given a new Discovery Sport as a loaner, very nice but does not feel like a Discovery. Really like the DAB, one station across 120 miles of travel today, excellent. Is there any solution to being able to get DAB on an 08 FFRR. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #328104 15th May 2015 6:36pm
Zirconblue
The last Jaguar X-Types came with DAB as standard. They use the same MOST optic network and the touch screens which are an even older denso design to the FFRR (similar software) support it.
They connect to the MOST system via some sort of gateway module, using a standard JLR DAB module which is apparently used in various LR and Jaguar models. I wonder if this 'gateway module' would allow the FFRR's system to have DAB? I suppose it will all boil down to whether or not the Range Rover's software will 'see' the module.
Post #328127 15th May 2015 8:53pm
please do try and if it works i'll be one of the first to follow in your footsteps.. Wink ... - .- -.
Post #328129 15th May 2015 9:13pm
Zirconblue
I'll add it to the list of things to do. Might be a while though. Laughing
Post #328188 16th May 2015 3:20pm
Chillb
After me Stan me old cocker Very Happy
Been using the Discovery Sport SE all weekend and a very nice capable car with a surprising amount of room inside. Just have to have the DAB on mine. Had and 07 X5 for 2 seconds (6 months) but it just did not work, this one is great. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #328339 17th May 2015 7:11pm
I'd be very surprised if the DAB unit would be "recognised" by the JLR system. I retrofitted a DAB tuner to my E60 5 series, which was an official option and it took several attempts by the garage to get it coded in.
Sadly, this isn't like a Windows plug'n'play type situation, so I would suggest you don't get your hopes up Big Cry Got - 2017 SDV8 Autobiography in Loire Blue
Post #328346 17th May 2015 7:46pm
Zirconblue
No i have my doubts too, the X-type uses a slightly earlier version of the JLR system (the X-type was running MOST in 2001, it was the first JLR product to do so) they didn't change the main hardware for the 2008MY. There might have been a software update, which could be the stumbling block on the Range Rover. On the Jaguar Xtype, X150 (XK) and S type the main stumbling block is installing an aerial, but it might be worth a try. If i can find the parts cheaply enough.
Post #328353 17th May 2015 8:11pm
Chillb
The other option to enable you to get the stations, certainly ones you like consistently across the UK are these after market ones that you tune in through your FM. Any decent discreet ones that anyone has tried and could recommend. You could mount out of sight tuned to the station you like and leave it. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #328363 17th May 2015 8:50pm
^ that's well documented on here - http://www.fullfatrr.com/forum/topic17064.html?highlight=dab. Mine (and a few others) like the Alpine EZ-DAB, which can connect via the AUX input and also can control iDevices. Got - 2017 SDV8 Autobiography in Loire Blue
Post #328385 17th May 2015 10:10pm
Page 3 of 4 <1234>
