Home > General > Are they wrong or am I? |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 |
dont think the "HSE" has a sunroof....only the vogue |
26th May 2012 7:54am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
All optional on an HSE... Dead give always are the dash top and grab handle/elbow rest will be in stitched leather in a vogue and in non stitched leatherette in an HSE the seats have an expandable seam running down from top to bottom and the front seats are a different shape and style in a Vogue...
26th May 2012 8:02am |
I have a Vogue badge on mine Present :2008 TDV8 HSE
26th May 2012 8:30am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7892 |
If someone actually lists it as an HSE then it probably is - the problem is usually the other way round because the FFRR doesn't have a name like 'Sport', there are a lot of people out there who generically refer to the model as Vogue, hence the Vogue HSE ad. You may see HSE's advertised as Vogues, even when still badged HSE !
26th May 2012 8:51am |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
My HSE certainly has, as mentioned, you could option an HSE with pretty much everything, which is one of the reasons I don't think I found 2 identical cars when looking for mine. I know what I drive, and I am happy with it, so I don't see a need to stick a Vogue badge on it... |
26th May 2012 10:09am |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
Mine is an HSE and apart from the Sunroof, mine is pretty much Vogue spec. As has been mentioned, I dont think no 2 are the same, depends what options were ordered from new. Mine was originally owned by a local(ish) wealthy business person and was driven by his wife, so he ordered alot of options. Would probably have been cheaper for him to have brought a Vogue for her anyway back in 2003!
26th May 2012 12:09pm |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 |
As others have said, the only real way to tell is the different seat style. |
26th May 2012 2:01pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3720 |
and even then, a lot of owners of older HSE's have bought Vogue seats from a breakers yard to upgrade their HSE's. The only categoric way is do a check on the VIN - any decent main agent should be willing to do this.
26th May 2012 9:35pm |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 |
And not to forgot the Vogue SE just to complicate matters |
27th May 2012 10:50am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
Here are the specs from the brochure, that I did for a different thread - hope you can enlarge and read OK ;
27th May 2012 12:18pm |
angelboy Member Since: 13 May 2012 Location: Retford Posts: 38 |
Excellent - thanks! |
27th May 2012 4:28pm |
wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161 |
Just to add more confusion, mine is a hse and has tons of extras including front and rear electric seats which according to above pics says was not available as an option for hse! 2003 Range Rover HSE 3.0 TD6
27th May 2012 6:33pm |
27th May 2012 7:22pm |
I'm not interested in this car but I think this is an example of an ad that's just wrong.
27th May 2012 10:25pm |
