Home > Technical (L322) > TDV8 BLOWING SMOKE |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1378 |
what colour of smoke?
25th May 2012 12:16pm |
KennyT Member Since: 25 May 2012 Location: Ireland Posts: 13 |
Its Black Soot, Billows out as long as I keep the foot down hard and I can see it clearly in the Mirrors. I have also noticed I have dropped from 23mpg to 21.5mpg but have put this down to me messing around with the throttle. If its over fuelling whats the solution. Not due a service for another 6k miles. |
25th May 2012 12:58pm |
This problem was solved by replacing the air intake pipe which had a small hairline crack in it (underneath). Crack was not visible from above and was a simple and cheap €25.00 fix. It has since happened to the other one but this time I knew and had it sorted in minutes. I have also seen this happen to a v8 BMW X5 |
1st Jun 2015 3:15pm |
jumbaleo Member Since: 19 Oct 2014 Location: Portsmouth Posts: 41 |
This happened to me, it was the Turbo inlet pipes, both rubber pipes were cracked on the underside. When I first noticed the smoke I thought i had blown a Turbo, but was very happy to find out after calling the independent it was a quick cheap fix. |
2nd Jun 2015 8:00pm |
Gunnerboy Member Since: 16 Aug 2015 Location: Hove Posts: 9 |
Can't take it back fellas emigrated!i I'll take the pipes off and check them they feel quite hard hope it's the easy option cheers. |
17th Aug 2015 5:47am |
