Home > Technical (L322) > TDV8 BLOWING SMOKE
KennyT
2007 Range Rover Vogue TDV8 Atacama Sand
TDV8 BLOWING SMOKE
2007 Range Rover TDV8 (120k miles) Blowing smoke (Lots of) on hard acceleration / kickdown. Engine running smooth and no loss of power. No smoke at idle. This smoke has only appeared approx 1 week ago. I have driven it hard in sport mode thinking it was carbon build up but as yet have not been able to clear it. I have read forums and seen suggestions re additives but as yet have not tried. Anyone had the same problem and been sorted with additive. Please any help greatly appreciated.
Cheers Thumbs Up
Post #123587 25th May 2012 9:44am
fisha
what colour of smoke?
black soot? ( overfuelling )
black/blue fumes? ( oil burning - bad breathers / turbo seals )
white/grey smoke? ( unburnt / partial burnt fuel - bad timing )
The above is extremely generic, but you can see that the colour can give pointers to the problem V8 or else ...
Post #123617 25th May 2012 12:16pm
KennyT
Its Black Soot, Billows out as long as I keep the foot down hard and I can see it clearly in the Mirrors. I have also noticed I have dropped from 23mpg to 21.5mpg but have put this down to me messing around with the throttle. If its over fuelling whats the solution. Not due a service for another 6k miles.
Post #123620 25th May 2012 12:58pm
KennyT
This problem was solved by replacing the air intake pipe which had a small hairline crack in it (underneath). Crack was not visible from above and was a simple and cheap €25.00 fix. It has since happened to the other one but this time I knew and had it sorted in minutes. I have also seen this happen to a v8 BMW X5
Post #330421 1st Jun 2015 3:15pm
jumbaleo
This happened to me, it was the Turbo inlet pipes, both rubber pipes were cracked on the underside. When I first noticed the smoke I thought i had blown a Turbo, but was very happy to find out after calling the independent it was a quick cheap fix.
Post #330659 2nd Jun 2015 8:00pm
Gunnerboy
United Kingdom 2007 Range Rover Vogue SE TDV8 Barolo Black
Can't take it back fellas emigrated!i I'll take the pipes off and check them they feel quite hard hope it's the easy option cheers. Confused
Post #342874 17th Aug 2015 5:47am
