![]() | Home > In Car Electronics (L322) > 2005MY (MOST) reversing camera |
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 ![]() ![]() ![]() |
Thanks very much Stan for your continued advice.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
you could piggy back onto an existing circuit or find one which is free due to maybe a item not being connected like rear heated seats for instance..
In fear of you wanting to strangle me, where would I conect the ground wire in that piggy back set up? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not |
ground it to any screw that goes into the body work, not 100% ideal but it works.. ... - .- -.
zetjester Member Since: 01 Apr 2013 Location: Northamptonshire Posts: 48 ![]() ![]() ![]() |
I have the pre face lift touchscreen FFRR and would like the rear camera. |
where you want to fit it depends on which type you get ...as for activating it , the only diagnostics that i know will do that is autologic, faultmate and IIDtool...i personally think that the latter is the best value for money.. ... - .- -.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
You need the cam switched on in the CCF.
Found a cam that will fit in place of the number plate light,
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 ![]() ![]() |
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 ![]() ![]() ![]() |
I finally connected up my reverse camera today (checked it was working first and no problems) and then installed. When I spliced into camera wires into the reversing lights, Brown (power) and Wht with yellow stripe (Earth?) coming out of the back of the reversing lap connector, i got a "Check Reversing Lights" error when tried the ignition (and no image).
