Home > In Car Electronics (L322) > 2005MY (MOST) reversing camera |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
possibly.. ... - .- -.
2nd Jul 2012 10:04am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6716 |
Have a look here, this is the kind of thing I had on my BMW :-
2nd Jul 2012 10:08am |
that screen is the same as the non-touch screen on the range ...the newer touch screens are different and because the signal travels down the MOST fibre optic cable ,the only way to get a reverse camera working is to connect directly to the rear of the screen and activate on the ccf. ... - .- -.
2nd Jul 2012 10:20am |
i'll have to drop that company an email later and ask... ... - .- -.
2nd Jul 2012 10:31am |
This is expensive :-
2nd Jul 2012 10:37am |
Or this one :-
2nd Jul 2012 10:43am |
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 |
I finally connected up my reverse camera today (checked it was working first and no problems) and then installed. When I spliced into camera wires into the reversing lights, Brown (power) and Wht with yellow stripe (Earth?) coming out of the back of the reversing lap connector, i got a "Check Reversing Lights" error when tried the ignition (and no image). Pulled it back out and the error went away. Plugged camera into the 12V jump started and it works well. Any ideas why id get an error splicing into the Reverse lights? More importantly what else could I use to get power from (preferably something in the tailgate that has power all the time)? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not L322 4.4 Vogue MY05 - Sold to my brother P38 4.6 HSE MY97 - Regretfully sold |
16th Jul 2012 12:55pm |
I would suspect you're getting the error because the LCM will be checking the impedance/resistance of the reverse circuit and when you add something in, this value changes, hence the error.
16th Jul 2012 1:02pm |
taking power from the reverse lights shouldn't cause errors, to be sure take a bulb out when trying..
16th Jul 2012 1:06pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
You can turn the cam on using Steve's, but you must have the correct firmware for the front entertainment module.
16th Jul 2012 3:15pm |
The image and screen work fine (I have a black box for that already installed), it switches to the cam when going into reverse.
17th Jul 2012 1:53am |
you could run a cable from the ciggy lighter socket in the back load area.. ... - .- -.
17th Jul 2012 8:15am |
I love that idea Stan thanks, I had the same thought and pulled it out, but it has three cables behind it and I didnt know which was which. Didnt want to blow up my house.
17th Jul 2012 12:39pm |
i've looked on rave and cant figure out which wire is which tbh...one point though, i'm not sure if the ciggy socket is on the ignition, if its a permanent feed then you might drain the battery ..
17th Jul 2012 2:02pm |
