![]() | Home > General > Is he being robbed? |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
A friend of mine had the gearbox pack up on his TD6 at the weekend. He's had it relayed to his local independent who services it for him... How much do you think for a replacement gearbox (fitted)?
Rykard Member Since: 16 Apr 2012 Location: Leicester Posts: 74 ![]() ![]() |
sounds a lot to me, my D2 had one in for about £1200 and I heard of a FF having one done last year for about £2500... can you give a hint to the indy? or is that against the rules? cheers
I can't give too much of a hint as I don't know them myself - All I know is that they are somewhere near Rainham in Essex. Also when they last had it for a service they backed it into a pillar, and allegedly changed the gearbox oil... |
not local then?
It's local to him!
Allegedly a new box - my concern there is that it might not have the better modified valve block. |
It sounds par for the course if they went to LR and bought a new box. And that is a rather silly way of going about fixing a transmission in a car only worth about twice to 3 times that at best, IMO.
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 ![]() ![]() ![]() |
£1600.00 for a replacement, from an Indi.
Cheers Paul - both of you!
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3872 ![]() ![]() ![]() |
http://www.kmotors.co.uk/index.php/automatic-gearboxes
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 ![]() ![]() ![]() |
probably the same "jason" i use..... ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
How do you get one with the updated valve body ? If that makes any sense ?
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
£3000 for mine from the dealer (td6) |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 741 ![]() ![]() |
Possibly a solution to some problems - Valve body |
