Home > General > Is he being robbed?
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Is he being robbed?
A friend of mine had the gearbox pack up on his TD6 at the weekend. He's had it relayed to his local independent who services it for him... How much do you think for a replacement gearbox (fitted)?
£4600+.... Seems a bit steep to me - guy assures him it's a genuine box from RR with 12 months warranty (but probably 12,000 miles - like all recons I suspect)...
If it's a new box and not a recon, will it still have the soft valve block problem?
Post #121089 10th May 2012 8:27am
Rykard
sounds a lot to me, my D2 had one in for about £1200 and I heard of a FF having one done last year for about £2500... can you give a hint to the indy? or is that against the rules? cheers
Rich
Post #121091 10th May 2012 8:31am
Simes
I can't give too much of a hint as I don't know them myself - All I know is that they are somewhere near Rainham in Essex. Also when they last had it for a service they backed it into a pillar, and allegedly changed the gearbox oil...
Post #121092 10th May 2012 8:33am
Rykard
not local then?
If he was local I would recommend the indy i use.. he did one last xmas used a guy in nottinghamshire for the rebuild I believe...
I had a recon from ashcrofts..
Rich cheers
Rich
Post #121094 10th May 2012 8:41am
Simes
It's local to him!
I use a guy called Jason - he comes to the house to do any work that I don't fancy doing and is really good value.
Post #121096 10th May 2012 8:49am
fisha
had my 4.4's box rebuild a few years back by Mackie transmissions in glasgow. top quality job. cost about £2700 all in. I think the Td6 box was a couple of hundred quid more. £4600 seems steep unless its a 100% new box. V8 or else ...
Post #121103 10th May 2012 9:43am
Simes
Allegedly a new box - my concern there is that it might not have the better modified valve block.
Post #121105 10th May 2012 9:49am
SteveMFr
Site Sponsor
It sounds par for the course if they went to LR and bought a new box. And that is a rather silly way of going about fixing a transmission in a car only worth about twice to 3 times that at best, IMO.
It will not have an uprated valve body if it is a new OEM box. But it will be new and not refurbed, so it should last another 100k miles.
1200-1500 is too little for a box with an uprated valve body, btw. Even with trained monkeys doing the work free... Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #121108 10th May 2012 9:56am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
£1600.00 for a replacement, from an Indi.
Of the 5 that I got through on my TD6 4 came from Land Rover and were reconditioned, not new!
Post #121109 10th May 2012 10:03am
Simes
Cheers Paul - both of you!
My thoughts were that it's too much money for a car with 140,000 miles on it, and that a decent recon (from a specialist) might last longer than a new box - and possibly cost a little less.
Post #121110 10th May 2012 10:07am
supershuttle
http://www.kmotors.co.uk/index.php/automatic-gearboxes
I don't have any feedback on, or make any recommendation for, this Indy other than they serviced and MOTd my car recently and they seemed OK (but thats hardly rocket science).
It's just to give an indication of the going rate which might be useful to you Whistle Geoff
Post #121132 10th May 2012 11:09am
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Simes wrote:
It's local to him!
probably the same "jason" i use..... Thumbs Up
Post #121152 10th May 2012 12:18pm
mjdronfield
How do you get one with the updated valve body ? If that makes any sense ?
If I have any issues, I'd want the replacement box not to have the same issues as the original unit..........
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #121170 10th May 2012 1:47pm
5IMON
£3000 for mine from the dealer (td6)
Post #121171 10th May 2012 1:48pm
Johnte
Possibly a solution to some problems - Valve body
Post #121189 10th May 2012 3:24pm
