![]() | Home > Technical (L322) > clonk from suspension |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
stevenA
Don't get too excited!
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
I've just removed my front drop links to see if they are causing the knocking (both new OEM parts in last 6 months) they're both fine & have no play. I went for a drive without the anti-roll bar drop-links and it's still knocking, so that rules out the anti roll bar and drop links. |
Another frustrating day.
New Landrover inner trackrod end fitted, still knocking.
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
I've just given up trying to solve this on mine ... turn the radio up loud enough and you don't hear it anymore ...
Thanks David will try that.
I would have thought it would have been blatantly bleedin' obvious by now I have NO CLUE where it is coming from!
Luckyluciano Member Since: 29 Oct 2011 Location: Wiltshire Posts: 121 ![]() ![]() ![]() |
I had a knock from the front suspension start a few months back.
Mine still knocks! Range Rover 4.4 V8 Vogue |
Mine too.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
mine still does NOT clunk (or clonk) since i followed the advise of stevena of loosening and tightening all suspension bolts with the Rangies wheels on the ground. |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
Mine is beginning to really |
Hunttheshunt Member Since: 02 Oct 2012 Location: Hants Posts: 92 ![]() ![]() ![]() |
Currently in Charente Maritime and I also have a clonky front suspension. However, what seems worse is that when steering slightly right there is a vibration that has started to get worse, feels like it is part of the right front suspension, assume its a bush or track rod end. Any ideas?? Have 600 miles to drive back before I can get it checked :0( |
