Home > Technical (L322) > clonk from suspension
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
stevenA
Can you please confirm the bush highlighted in the pic below is the compliance bush.
Ta
David
[/img]
Post #120042 3rd May 2012 8:57am
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I've just checked the bush you highlighted David with a pry bar, it was changed when I got the car at the main agents. I've only had the car about 6 months & the bush is worn out! This could be the place that's knocking! I'll replace it when I get chance, just assumed that because it was only 6 months old it couldn't be worn out. I changed everything trying to find this bloody knocking Rolling Eyes Range Rover 4.4 V8 Vogue
Post #120971 9th May 2012 10:55am
rads
Don't get too excited!
That bush (actually the whole arm) was one of the first bits I changed. Still knocks!
I think the off side arm was changed before I bought it, I do wonder if the knock could be transferring over, and the off-side arm was not tightened with the weight on the wheels? Something else to try.
David
Post #120977 9th May 2012 11:17am
Glideman
I've just removed my front drop links to see if they are causing the knocking (both new OEM parts in last 6 months) they're both fine & have no play. I went for a drive without the anti-roll bar drop-links and it's still knocking, so that rules out the anti roll bar and drop links. Big Cry Question is do they have a right way up? Just something else to check while it's in bits Confused Range Rover 4.4 V8 Vogue
Post #121331 11th May 2012 5:55pm
rads
Another frustrating day.
My knock had got much worse, so bad I was sure I would find it this time.
Got the car rocking by jumping up and down on the side steps, quickly found play in the N/S ARB drop link (less than 8 months old).
Took both drop links off, went for a drive, Much Better, but original knock (man holes, pot holes) still there.
Big Cry
Had read a post elsewhere where someone fixed a knock by tightening the washer fluid reservoir. Mine was not loose, but there was some play in the lower attachment clip. Took off all the under trays, managed to force a piece of thin rubber into the clip, no more play!
Still knocking
Big Cry
Had bought new inner and outer track rod ends a month or two back (shotgun principal).
Went to change these but found the Moog inner track rod end is not a suitable replacement, has much less articulation than the original.
Found out when trying to put everything back together, and couldn't get the track rod low enough to engage the new ball joint with the hub. So had to take it all apart again and re-fit the old inner.
Mad
Finally, carefully reassembled alll the undertrays, replacing missing spire clips and screws so now all the undertrays are tight and rattle free.
Knock still there.
Big Cry
Ho hum.
David
Post #122836 21st May 2012 10:12am
rads
New Landrover inner trackrod end fitted, still knocking.
Big Cry
I'm changing track a bit.
Glideman, try thumping the gearbox sub-frame. I get a slight metallic noise from the front left corner, could be the knock.
Problem is, subframe bushes don't seem to be listed as a separate part, and the complete subframe is a �200 (edit, thanks Dan) plus part, and I'm not that confident.
More digging to do...
David
Post #123602 25th May 2012 11:58am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
I've just given up trying to solve this on mine ... turn the radio up loud enough and you don't hear it anymore ...
Going to work on the rear bushes this weekend - hopefully that solves the cart spring squeak! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #123614 25th May 2012 1:01pm
Glideman
Thanks David will try that.
The noise isn't coming from the catalytic converter is it? Sounds a bit heavy for that though Confused
Colin Range Rover 4.4 V8 Vogue
Post #123621 25th May 2012 2:17pm
rads
I would have thought it would have been blatantly bleedin' obvious by now I have NO CLUE where it is coming from!
Wink
Does sound too heavy, clonk not rattle.
Bit like a gearbox sub-frame might sound!
David
Post #123622 25th May 2012 2:27pm
Luckyluciano
I had a knock from the front suspension start a few months back.
Nothing major at first but over the last week it got louder and louder.
So after doing some research on here I at least new where to look. Getting a friend to rock the car I noticed the droplinks had a lot of play in them so thought it was best to start with them.
This is what the old ones looked like when removed.
Shocked
Well with the new ones fitted the knock has gone and the car feels great Very Happy
So a big thank you too all for the info :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Range Rover Autobiography 5.0SC
Range Rover Vogue 4.4 V8 SOLD
Aston Martin V8 Vantage
Post #123774 26th May 2012 8:01pm
Glideman
Mine still knocks! Range Rover 4.4 V8 Vogue
Post #205013 20th Aug 2013 10:59pm
rads
Mine too.
Sad
How are the diffs mounted to the subframe?
David
Post #205901 27th Aug 2013 11:31am
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
mine still does NOT clunk (or clonk) since i followed the advise of stevena of loosening and tightening all suspension bolts with the Rangies wheels on the ground. Mr. Green
Post #206225 28th Aug 2013 7:49pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Mine is beginning to really Censored me off now! I'm still getting a knock/ creak when turning right. It comes from near side And had an obviously failed lower arm. I also changed the ball joint but still it makes the noise!
Just ordered a pair of drop links cos they're only a fiver each so thought I'd give those a go first! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #206299 28th Aug 2013 10:33pm
Hunttheshunt
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Currently in Charente Maritime and I also have a clonky front suspension. However, what seems worse is that when steering slightly right there is a vibration that has started to get worse, feels like it is part of the right front suspension, assume its a bush or track rod end. Any ideas?? Have 600 miles to drive back before I can get it checked :0(
Post #206653 29th Aug 2013 11:27pm
