Home > Technical (L322) > clonk from suspension
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
Your advice is needed
2004 v8 is making clonking noise from suspension (front) when turning left or right. Thus far everything on the front suspension has been replaced but the noise is still there
What else can it be Big Cry
Post #118147 18th Apr 2012 2:58pm
....it could be a 'clunk'..
found using search..
http://www.fullfatrr.com/forum/topic10085.html ... - .- -.
Post #118153 18th Apr 2012 3:18pm
Stan the search system is very difficult to use mate, I guess sometimes questions have to be asked Very Happy
Post #118154 18th Apr 2012 3:23pm
ebajema
I wonder if Stan just has this awesome memory, instead of using the search function. Who knows, Stan may be the real secret of Googles success but wants to remain anonymous Smile Come on mate, you can tell us Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #118157 18th Apr 2012 3:35pm
the search function [with instructions how to use] is there in addition to the OP being able to scroll down and flip a few pages to find threads with the same subject.
OP probably did search for 'clonk' hence my suggestion of clunk and the link .... ... - .- -.
Post #118158 18th Apr 2012 4:18pm
Post #118160 18th Apr 2012 4:43pm
vnitos
compliance bush on ffrr
where one find the compliance bush on the range rover and any idea how to set/replace it - apparently it contributes to the clunking noise [/u]
Post #118428 20th Apr 2012 1:48pm
Reformed
Are you sure its not the drop links. Cheap and easy to change, don't even need to jack the car up to change them? Reformed
Post #118433 20th Apr 2012 2:03pm
Front suspension consists of bottom balljoints, drop links, anti-roll bar 'D' bushes, compression links and transverse links
Never heard of a compliance bush and can only think it's a mechanic getting his bushes mixed up. It could be the bushes in the compression links or transverse links
Post #118438 20th Apr 2012 2:12pm
vnitos
thanks for the reply. thus far we've replaced drop links, lower arm bushes, tie rod ends, etc. the only things on front suspension that has not been replaced are the struts and shocks[/url]
Post #118439 20th Apr 2012 2:13pm
I'll try my dead cat in the engine undertray again Laughing .
Post #118451 20th Apr 2012 3:30pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
The bush that connects the tie rod to the subframe is a compliance bush (see microcat) and is located just below the height sensor -it is a round bush with an asymetric core. If it is not aligned correctly, movement of the lower arm, instead of being absorbed by the bush, cause the inner and outer parts to touch hence the clunk.
This has to be slackened to do the diff mod, and at least on mine, was not correctly tightened when it was tightened - it must be tightened with the weight on the wheel, but is much easier to tighten with the wheel hanging down on a lift.
To see if this is the issue, compare both sides as the diff mod only required one side to be slackened. Look at where the inner part of the bush is contacting the outer part - the maximum rubber should be in a horizontal plane, but if tightened with the wheels in the air, it will be pointing up at 45 degrees, leaving less rubber to absorb shocks.
The bolt that retains it is tightened to 165 Nm = 90 Degs if I remember correctly, and it can often be fixed just by slacking it with the weight on the vehicle - you will here a clunk as it rotates to the correct position, but beware, it is very hard to tighten without a pit!
Post #118484 20th Apr 2012 7:02pm
vnitos
hi steven
thanks for the info. we did just the above, however it seems not to have resolved the issue. is there anything else that we should try. thanks
Post #118973 25th Apr 2012 10:01am
stevenA
Perhaps this is not the problem!
Two quick questions which may help:
1. Before changing anything, were the bushes aligned and touching in the correct axis (you can see the contact point on the bush)?
2. Did the bushes rotate when you released the torque with the vehicle weight on the wheels, particularly if the answer to 1 was that the contact point was not in the axis of the bushing?
Hope this helps
Steve
Post #119399 27th Apr 2012 10:33pm
vnitos
suspension clonk, or rather clunk, gone
eventually the clunk has disappeared. solution to the irritation, loosening and tightening the subframe as well as all joints and bushes with the car on all 4 wheels on the ground and, voila clunking gone.
the cause of the problem - replacing the bushes and other suspension parts whilst the car was on a lift with wheels hanging
thanks stevena for the heads up, really appreciate your advice
Post #120035 3rd May 2012 7:35am
