Home > Technical (L322) > RRPhil |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
If you have 7045E in the gearbox can I take it it is OK to mix Dexron VI with it during a first change? John
6th Oct 2015 2:41pm |
Thanks Phil 👍 Best get some ordered and something to fill the box back up with I guess! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
6th Oct 2015 9:10pm |
Well found a tub of 20l of dexron VI for £82.50 delivered if anyone near Warrington/Manchester/Liverpool wants to go halves? Enough for at least one change and a partial flush if so wanted but I believe if drained when warm almost all the old oil bar maybe .5-1litre should be left in the box? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
6th Oct 2015 9:23pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I got 20 ltrs of Texaco 7045E for £87 ish delivered, that's 2 flushes or 4 oil changes Just do a search for 7045E and you'll soon find a bargain
6th Oct 2015 10:10pm |
I had seen it had come down in price a little but why bother with an older oil? If Dex 6 is whats specced now then its going to be better for the box otherwise they would still be sticking with the 7045.
7th Oct 2015 10:15am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8191 |
I think you will find he is a ZF5HP24 man and doesn't have much to do with the GM box apart from sympathy.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
7th Oct 2015 10:38am |
Sorry Pete , should have read "sleeping, eating and having nightmares"
7th Oct 2015 12:00pm |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
I have also struggled to get in touch with you Phil, I sent you a PM a few months back with all my gearbox troubles but you must have forgot about me 2004 RR 4.4 V8 Autobiography |
7th Oct 2015 1:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
RR phil has mentioned before that he will not respond to pm's or emails because of the great quantity he gets..
7th Oct 2015 1:51pm |
Hi Stan, I did do just that. I posted on the forum back in May about my gearbox issues and got no help except from haylands who tried his best. I gave up asking after that and my RR is still sat in the drive not working 2004 RR 4.4 V8 Autobiography |
7th Oct 2015 2:21pm |
Phil holds down a more than full time job as well, he does his best and gets on here when he can, as Stan says he has turned off his PM's as he was getting dozens a day.... Pete
7th Oct 2015 2:27pm |
hopefully phil will see this and offer his advice paul,
7th Oct 2015 2:45pm |
Thanks very much Stan 2004 RR 4.4 V8 Autobiography |
7th Oct 2015 3:00pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
The only feedback that the transfer box ECU (& indirectly the transmission ECU) receives to tell it what range is selected on the NV225 is the voltage signal from the shift motor potentiometer. If it loses that signal for any reason then it will immediately failsafe the transmission as it has no idea what range it’s in. You need to check that the resistance between pins 1 and 2 is around 4.7 kilohms.
7th Oct 2015 5:39pm |
Phil, Still curious about mixing 7045E and Dextron VI. John
7th Oct 2015 7:03pm |
