Home > Technical (L322) > RRPhil
Page 2 of 3 <123>
Weegie
If you have 7045E in the gearbox can I take it it is OK to mix Dexron VI with it during a first change? John
GAP iiD BT
Post #350896 6th Oct 2015 2:41pm
Thanks Phil 👍 Best get some ordered and something to fill the box back up with I guess! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #350952 6th Oct 2015 9:10pm
Well found a tub of 20l of dexron VI for £82.50 delivered if anyone near Warrington/Manchester/Liverpool wants to go halves? Enough for at least one change and a partial flush if so wanted but I believe if drained when warm almost all the old oil bar maybe .5-1litre should be left in the box? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #350954 6th Oct 2015 9:23pm
miggit
I got 20 ltrs of Texaco 7045E for £87 ish delivered, that's 2 flushes or 4 oil changes Thumbs Up Just do a search for 7045E and you'll soon find a bargain Thumbs Up
Geoff the GM 5L40E's valveblock is made from cheese, but most of it is en croute (pastry, easier to shape and slightly more solid) Rolling with laughter
And Craig, I know that Phil's got a reputation sleeping and eating GM 5L40E gearboxes, but I don't think that it is literal, he might get the hump if you feed him just on gearboxes, you might want to consider opening the door and throwing a happy meal in there every now and then Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #350958 6th Oct 2015 10:10pm
I had seen it had come down in price a little but why bother with an older oil? If Dex 6 is whats specced now then its going to be better for the box otherwise they would still be sticking with the 7045.
With Phil recommending it as well thats enough for me Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #350982 7th Oct 2015 10:15am
I think you will find he is a ZF5HP24 man and doesn't have much to do with the GM box apart from sympathy.... Pete
Post #350985 7th Oct 2015 10:38am
miggit
Sorry Pete Embarassed , should have read "sleeping, eating and having nightmares" Rolling with laughter
And being a ZF man just makes it easier to spot the shortfalls of the GM box Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #350993 7th Oct 2015 12:00pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I have also struggled to get in touch with you Phil, I sent you a PM a few months back with all my gearbox troubles but you must have forgot about me Crying or Very sad Confused 2004 RR 4.4 V8 Autobiography
Post #351021 7th Oct 2015 1:43pm
RR phil has mentioned before that he will not respond to pm's or emails because of the great quantity he gets..
if you do have a question re gearbox's then post on the forum, any answers will help other members if they have the same problems. ... - .- -.
Post #351027 7th Oct 2015 1:51pm
PaulM
Hi Stan, I did do just that. I posted on the forum back in May about my gearbox issues and got no help except from haylands who tried his best. I gave up asking after that and my RR is still sat in the drive not working Sad 2004 RR 4.4 V8 Autobiography
Post #351032 7th Oct 2015 2:21pm
Phil holds down a more than full time job as well, he does his best and gets on here when he can, as Stan says he has turned off his PM's as he was getting dozens a day.... Pete
Post #351034 7th Oct 2015 2:27pm
hopefully phil will see this and offer his advice paul,
http://www.fullfatrr.com/forum/post329520.html#329520 ... - .- -.
Post #351037 7th Oct 2015 2:45pm
PaulM
Thanks very much Stan Smile 2004 RR 4.4 V8 Autobiography
Post #351039 7th Oct 2015 3:00pm
RRPhil
The only feedback that the transfer box ECU (& indirectly the transmission ECU) receives to tell it what range is selected on the NV225 is the voltage signal from the shift motor potentiometer. If it loses that signal for any reason then it will immediately failsafe the transmission as it has no idea what range it’s in. You need to check that the resistance between pins 1 and 2 is around 4.7 kilohms.
This is the manual recalibration procedure for the shift motor :
It sounds to me like there may still be an issue with your inhibitor switch. I know that they’re stupid money to buy, so it would be pretty risky just to replace it, but I can certainly lend you one to try if you want to isolate the fault through substitution.
Phil
Post #351065 7th Oct 2015 5:39pm
Weegie
Phil, Still curious about mixing 7045E and Dextron VI. John
GAP iiD BT
Post #351084 7th Oct 2015 7:03pm
Page 2 of 3 <123>
