Home > Maintenance & Mods (L322) > spacers on rear
spacers on rear
has anyone fitted spacers on the rear to bring out the wheel/tyre a bit more ....just curious whether its a worthwhile job.. ... - .- -.
Post #112601 12th Mar 2012 12:11pm
anyone? ... - .- -.
Post #343287 19th Aug 2015 2:44pm
Welshdragon
Bit confused why you would want to Stan? If it dont work.......burn it!
Post #343288 19th Aug 2015 2:56pm
not sure i would Mike but when you look at the rear wheels they do seem as if they need to come out a bit... ... - .- -.
Post #343289 19th Aug 2015 3:00pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Got them on the MG stan (Came with it not fitted by me) they do push the wheels out a bit and fill the arch nicely.
However on the FF I would be worried about the strain on the wheel as the weight should be taken by the centre of the hub not by the wheel nuts and bolts.
ta
Andy Mine was a blue one! Smile
Post #343290 19th Aug 2015 3:01pm
found these on ebay and it looks like the spacers bolt onto the existing studs and the wheels bolt onto the spacer studs....not sure on the strains on the hub this would cause..
Post #343293 19th Aug 2015 3:09pm
Welshdragon
People I know who fitted spacers on other green ovals have had issues with wheel bearings going, but then with off set wheels they would!
I've not had experience on spacers so can't comment, but I too would be concerned.
Stan your ff looks fine.......stop fettling with it! Laughing
( you got me looking at the sunroof switch yesterday ) Twisted Evil Laughing If it dont work.......burn it!
Post #343294 19th Aug 2015 3:09pm
Andy3681
They would be better Stan as you would still support on the hub, The ones on MG are just flat plates with slotted holes, Very boy racer. However +1 for wheel bearings Mine was a blue one! Smile
Post #343295 19th Aug 2015 3:15pm
I'm amazed that question has been on here for 3 1/2 years and nobody replied....
I know what you mean Stan, the rear track is in fact 3mm narrower than the front, I kid you not, you must have noticed that...!!!
Lad on the other forum had them on his 90, one snapped and his wheel fell off....
They do universal ones in 3mm 5mm 10mm etc that just slip over the original studs but that just means you have less threads in the nuts... not a good idea... Pete
Post #343296 19th Aug 2015 3:19pm
@Mike, i'll find something else for you to look and fettle with Laughing
@andy, these spacers do look safer.. Thumbs Up
@pete, seen the 'slip on' type and they dont give me confidence.. ... - .- -.
Post #343300 19th Aug 2015 3:32pm
Lost for Words
Should be fine just as long as they're good ones. In particular, note Mikey's pics: http://www.disco3.co.uk/forum/topic130597.html Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #343302 19th Aug 2015 3:46pm
interesting, thanks.. Thumbs Up ... - .- -.
Post #343303 19th Aug 2015 3:51pm
Silversurfer13
United Kingdom 2008 Range Rover Autobiography TDV8 Java Black
Proper companies like Eibach and H&R do them and it's quite popular in the Middle East.....
I understand the going choice is 20mm at the front and 30mm at the rears.
Post #343507 20th Aug 2015 10:04pm
rangie47
I put wheel spacers on my old td5 disco,
because I put a 3'' lift on it with bigger tyres to save rubbing issues ,
but I also liked the stance,
I found the wider track gave it better footing,
if you do go for some make sure there hub centric as the 1's in your pic ( no wheel wobble ),
they caused no problems with my hubs ,bearings etc,
a good make is needed ,I had terrafirma. 2007 tdv8 se ,stornaway grey
Post #343513 20th Aug 2015 10:23pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Had them on my disco 3 with no issues. I will be getting some for the ff. must be Hubcentric and of good quality tho.
Only do a handfull of miles so wheel bearings don't concern me that much.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #343587 21st Aug 2015 11:29am
