Home > Maintenance & Mods (L322) > spacers on rear
is that for the rear only Steve?
when you fit can post pics please.. ... - .- -.
Post #343588 21st Aug 2015 11:30am
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
No stan. I did front and rear. In my op it gives it a much better look. I will post up as and when.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #343638 21st Aug 2015 3:33pm
Thumbs Up ... - .- -.
Post #343639 21st Aug 2015 3:34pm
Whistle Wink ... - .- -.
Post #344906 28th Aug 2015 5:37pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Why not get some new wheels and change the offset it'll have the same effect without the worry of whether or not your wheels going to snap
Post #344909 28th Aug 2015 6:35pm
johnboyairey
i think you will find that the (quite good) turning circle (on the FFRR) will be quite different, -maybe as bad as the old td5 that we had, ie minimum 9 point turn etc. could it also, threaten the front wing lip when turning/hard cornering, with body roll?
Stan, -did you used to drive a ford cortina, and have those jack up leaf spring blocks, and a red light shining on the axle, at night, at maccy-dee's. they ued to use those spacers.
next you'll be on about a really long CB type aerial, tied back on the roof gutter!
Razz
Post #344910 28th Aug 2015 6:55pm
@ivor, RRS wheels are 9.5j so that would work on the back but i dont want wider on the front so thats out..
@john, not a cortina but i did that on a capri Mr. Green
its not a done deal that i will do this , i'm mostly curious on what it would look like and how they perform.. ... - .- -.
Post #344913 28th Aug 2015 7:26pm
Ivor
I run staggered fitment on my skyline most companies can accommodate even if means buying them separately
Post #344938 28th Aug 2015 11:44pm
