Home > Wheels & Tyres > "e" mark..?
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
"e" mark..?
I got 4 255/50/20 Pirelli scorpions, I can't find the e mark and we fail the nct here In Ireland if they don't have it.I have my Sunday glad rags on, can anyone confirm where the e mark is on these tyres..? Also what's the best psi when inflating them, only got them on fri and they look a little soft already..
Post #112414 11th Mar 2012 3:28pm
Do you often run with a load in the back or just yourself and 1-2 copilots??
For the latter
36psi
38psi
Front
Back
For the former
38
42
With the higher pressures drop em back down if your running light for any period of time otherwise the centre d the rear tires wears quickly...
Can't help with the e mark but maybe check the pirelli site or google?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112433 11th Mar 2012 4:41pm
Lolo
Thanks Thumbs Up
Post #112437 11th Mar 2012 4:49pm
Tbh I run mine just below the max most of the time as I carry speed into corners which keeps wear even enough Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112438 11th Mar 2012 5:15pm
Is this what you are meaning Lolo ….
Just bottom right of the Pirelli stamp marking ….
Post #112439 11th Mar 2012 5:16pm
not pirelli lolo, but general tyre info that might help..
Post #112441 11th Mar 2012 5:24pm
Lolo
Thanks guys I'll have to get under car to have a look at the other side of the tyres so..the e is on one tyre on the outside so I am assuming the marks are on the inside of the other ones, please g0d.. Thumbs Up
Post #112449 11th Mar 2012 5:44pm
No the e mark is on all the tyres on the outside , you don't need to get under the car , Whistle
Post #112451 11th Mar 2012 5:47pm
Lolo
Well if that's the case I'm well p Censored d off cause no e marks on my 3 pirellis, could that mean dodgy knock offs? Joker are u sure the e marks on ur scorps are on the other side also..?
Post #112455 11th Mar 2012 5:55pm
Right you are starting to lose me , on all my four Pirelli's the "e" mark is on the four separate tyre walls of each tyre …. if it is marked on the inside i don't know but at a guess i am thinking it should be …..
Post #112458 11th Mar 2012 5:58pm
Lolo
Ur easily lost so.. Laughing well when u get a chance can u check the insides( as in the other side of ur tyre walls )to see if the e marks are on them. My tyres were part worn so I am assuming when the were fitted the guy put the worn/scuffed walls on the inside.. Thumbs Up Bow down
Post #112462 11th Mar 2012 6:04pm
Yes Mick, get your ass under the FFRR and check your e-marks
Post #112465 11th Mar 2012 6:06pm
Check the inside's , you having a Giraffe , Laughing Laughing Laughing
Post #112466 11th Mar 2012 6:07pm
Lolo
Ah go on, are u not curious..? Very Happy
Post #112470 11th Mar 2012 6:09pm
No ….
Post #112471 11th Mar 2012 6:10pm
