Home > Wheels & Tyres > "e" mark..? |
Do you often run with a load in the back or just yourself and 1-2 copilots??
11th Mar 2012 4:41pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Thanks |
11th Mar 2012 4:49pm |
Tbh I run mine just below the max most of the time as I carry speed into corners which keeps wear even enough FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
11th Mar 2012 5:15pm |
Is this what you are meaning Lolo ….
11th Mar 2012 5:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
not pirelli lolo, but general tyre info that might help..
11th Mar 2012 5:24pm |
Thanks guys I'll have to get under car to have a look at the other side of the tyres so..the e is on one tyre on the outside so I am assuming the marks are on the inside of the other ones, please g0d.. |
11th Mar 2012 5:44pm |
No the e mark is on all the tyres on the outside , you don't need to get under the car , |
11th Mar 2012 5:47pm |
Well if that's the case I'm well p d off cause no e marks on my 3 pirellis, could that mean dodgy knock offs? Joker are u sure the e marks on ur scorps are on the other side also..? |
11th Mar 2012 5:55pm |
Right you are starting to lose me , on all my four Pirelli's the "e" mark is on the four separate tyre walls of each tyre …. if it is marked on the inside i don't know but at a guess i am thinking it should be ….. |
11th Mar 2012 5:58pm |
Ur easily lost so.. well when u get a chance can u check the insides( as in the other side of ur tyre walls )to see if the e marks are on them. My tyres were part worn so I am assuming when the were fitted the guy put the worn/scuffed walls on the inside.. |
11th Mar 2012 6:04pm |
Yes Mick, get your ass under the FFRR and check your e-marks |
11th Mar 2012 6:06pm |
Check the inside's , you having a Giraffe , |
11th Mar 2012 6:07pm |
Ah go on, are u not curious..? |
11th Mar 2012 6:09pm |
No …. |
11th Mar 2012 6:10pm |
