Home > Technical (L322) > Broken sidemirror. Need help!
Mounty
Switzerland
Need help. Can be just the motor replaced? One dealer says yes, the other no that you have to replace the whole thing. Can anybody have may have a look in microcat if that helps. Somebody mus hung on the whole mirrir. Broken is only the motor. The case split in half. Got pics. But don't manage to put them here Embarassed I know that you can order the motor seperately. Daniel
Past:FFRR 2004 Vogue 4.4l bonnatigrey/sand/ burr walnut
Modifications: SC grill (not fixed) SC MY10 sidevents (not fixed), MY10 Letters front and back, clear sidelights , MY10 rear lights (not fixed), MY09 steering wheel trims, new MY09 sterringwheel 19'' seven spoke wheel (not fixed) 19'' MTS (not fixed), 20 '' wheels, doorhandelcovers brunel (not fixed), complete doorhandels (not fixed) burr walnutdoorsouround (not fixed)
Post #109727 27th Feb 2012 6:06pm
Hi, try this my friend... eBay item number eBay Item No. 160730921926
Genuine OE drivers side door mirror motor with memory setting.
Models: Range Rover Sport, Range Rover L322 & Range Rover Evoque
Part No: CRP500041 £21.10
Craig Thumbs Up
Post #110002 28th Feb 2012 10:55pm
GJOB
2005 Range Rover Vogue SE Td6 Java Black
Hi Mounty, yes you can but you have to break 3 small bits of plastic to separate the front and back covers. I did just that at the weekend with the help from DavidP who sent me photos.
There are different mirrors dependent on model year, if you send a pic of the mirror we'll know which instructions you'll need.
hth
GJOB
Post #110195 29th Feb 2012 10:52pm
03rangiemark
United States 2003 Range Rover HSE 4.4 V8 Java Black
Re: Broken sidemirror. Need help!
Mounty wrote:
..the motor...
The side view mirror has two motors. The one that folds the entire mirror assembly, for fitting into tight spaces, and the one that adjusts the angle of the mirror within the assembly.
Which one are you asking about? 03 HSE Range Rover (U.S. Spec)
Black
All stock
Post #110431 2nd Mar 2012 12:34am
Mounty
Switzerland
Thanks for your help. After I send more pics to my trusted dealer in GB nad CH. I had to replace the whole thing Crying or Very sad . Daniel
Post #110523 2nd Mar 2012 3:23pm
