Home > Technical (L322) > Broken sidemirror. Need help! |
Mounty Member Since: 29 Jan 2009 Location: Allschwil Posts: 311 |
Need help. Can be just the motor replaced? One dealer says yes, the other no that you have to replace the whole thing. Can anybody have may have a look in microcat if that helps. Somebody mus hung on the whole mirrir. Broken is only the motor. The case split in half. Got pics. But don't manage to put them here I know that you can order the motor seperately. Daniel
27th Feb 2012 6:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Hi, try this my friend... eBay item number eBay Item No. 160730921926
28th Feb 2012 10:55pm |
03rangiemark Member Since: 27 Feb 2012 Location: Orlando, Florida Posts: 7 |
The side view mirror has two motors. The one that folds the entire mirror assembly, for fitting into tight spaces, and the one that adjusts the angle of the mirror within the assembly. Which one are you asking about? 03 HSE Range Rover (U.S. Spec) Black All stock |
2nd Mar 2012 12:34am |
Thanks for your help. After I send more pics to my trusted dealer in GB nad CH. I had to replace the whole thing . Daniel
2nd Mar 2012 3:23pm |
