Home > General > Rear Screen - do you have a lower trim?
Page 1 of 3 123>
rich_959
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Folks - I have a plastic/rubber trim along the bottom of my rear windscreen and I noticed on another FF I was following this morning that it didn't have one. I then walked past another FF in our carpark which also didn't have it. Did some cars have this, and some not? Or have both of the cars I've seen just lost the trim?
Rich.
Post #108188 20th Feb 2012 12:30pm
should be one ...its between the bottom of the glass and the top of the metal part of the upper tailgate.. ... - .- -.
Post #108189 20th Feb 2012 12:40pm
rich_959
Yeah, that's the one, cheers Scarey. Mine doesn't seem to be completely right after a warranty tailgate replacement and I'm just deciding whether to ask for the trim to be replaced or not.... I think I'll let sleeping dogs lie and put up with it.
Post #108190 20th Feb 2012 12:45pm
hopefully it wont leak water.. Wink ... - .- -.
Post #108191 20th Feb 2012 12:48pm
rich_959
Fairly sure it's just a cosmetic piece of trim, rather than forming part of the seal. You had to place doubt didn't you!! Big Cry
Post #108193 20th Feb 2012 12:49pm
simon1233
rich, I have a 57 plate 2008MY model and it doesn't have a trim at the bottom of the rear screen Thumbs Up
Post #108196 20th Feb 2012 12:59pm
pic...... seems to keep the glass from knocking the metal..
Post #108199 20th Feb 2012 1:06pm
rich_959
Cheers Simon. Hmm. The 2 cars I've seen without the trim were 57 plates (and yours makes 3) and mine is an 07 WITH the trim. Wonder if it's a variation across the years. I'll be looking at every car I see now!!
Post #108201 20th Feb 2012 1:08pm
note to myself...clean the bloody range.... Mr. Green ... - .- -.
Post #108202 20th Feb 2012 1:08pm
rich_959
Thanks for the pic Scarey, that's the one. On the cars I've seen without the trim, there seems to be a bit of clearance between the glass and bodywork. The trim on mine (and as per your pic) just looks like a finishing strip to match the way it's finished on the side windows. So has it fallen off these cars, or been removed, or intentionally omitted at the factory I wonder....
Post #108205 20th Feb 2012 1:12pm
i'll be looking at them now.. Laughing ... - .- -.
Post #108206 20th Feb 2012 1:14pm
Johnte
Mines the same Thumbs Up 2006MY
Post #108208 20th Feb 2012 1:15pm
simon1233
Here's the back of mine to start you off with this weird hobby of seeing who does and does not have a finishing strip Mr. Green
IIRC MY2008 onwards did not have the little rubber strip at the bottom of the rear screen.
Post #108211 20th Feb 2012 1:23pm
rich_959
Ha ha, what have I started! Should have made it a survey Wink
Post #108214 20th Feb 2012 1:31pm
The finishing strip was dropped on later models for a cleaner fresher look.
Its one way that an older model 2010/11/12 conversion can be recognised.
For the record the trim slides out sideways with light tapping with an appropriate instrument....
IMHO opinion it looks much better without it.
Gary
Post #108221 20th Feb 2012 2:06pm
Page 1 of 3 123>
