Home > General > Rear Screen - do you have a lower trim?
Page 3 of 3 <123
you got a good memory adam, that was back in 2009... ... - .- -.
Post #108334 20th Feb 2012 10:43pm
rich_959
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Cheers guys, and apologies for the topic duplication Rolling Eyes
Must get better at using the search.
Gave mine a tap with a mallet and a small piece of wood last night but it didn't budge at all. Too scared to use the screwdriver method to pop it off the bottom!
Post #108414 21st Feb 2012 2:36pm
If it was fitted I would leave it be, its most likely got some adhesive holding it in place too.
If it ain't broke, don't fix it, otherwise it can only lead to problems IMHO. Discovery 4 HSE
Post #108444 21st Feb 2012 4:55pm
rich_959
Yeah, but it is broke - that's the thing. It's got a wavy bit in the middle where it doesn't fit quite flush to the body at the bottom. I'll have it back to the bodyshop who did the tailgate and get them to either remove or replace it before my ham-fistedness breaks something expensive!
Post #108446 21st Feb 2012 4:57pm
Mutley
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
My RR My08 is trimless Mr. Green Mutt
FFRR Black TDV8 Vogue MY08
Post #108458 21st Feb 2012 5:54pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
My FFRR MY06 has it fitted. A friends 05 does not - pointed it to him earlier on. Neither of us had ever noticed.
Post #108509 21st Feb 2012 9:24pm
Astron21
Russia 2007 Range Rover Supercharged Supercharged Java Black
I think they started to use DED500180/190 side seals instead.
My MY 2007 has the lower seal, but MY 2012 doesn't but has these side seals.
Post #137506 24th Aug 2012 7:34am
joshydee
2002 Range Rover Vogue 4.4 V8 Stornoway Grey
I removed the strip on mine, but the gap it leaves in much larger than that on the models without the strip. So i had the glass removed and refitted with the correct gap, while it was out i fitted the 2 side seals which are fitted on the later models. The seals are lead coated in rubber and fit to each side of the glass, at the bottom they are angled which allows you to sit the rear screen in the right place when bonding the glass back in. The side seals are actually have a design flaw, they bubble badly at the bottom, my friends 60 plate FF have bubbled really badly, and the parts guy at LR told me they have replaced a LOT under warranty.
I also now look at every FF to see if is has the strip, its annoying.
Hope this helps Smile
Post #138028 27th Aug 2012 7:08pm
Page 3 of 3 <123
