![]() | Home > Maintenance & Mods (L322) > Wiper "thud' on direction change |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
£16/17 or a 40 mile journey.....which is better? ... - .- -.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
My thud has come back - doh! Geoff |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
I got carried away with this thread and ordered a set off eBay too, even though my "thud" was more of a "gentle bump".
geoff, that thud you now get might be due to the wipers cleaning the screen to well .... ... - .- -.
Stan,
yep my screen is the same , might have to accidentally get a large stone chip but then that will cost me about £70 excess charge..
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Ditto after just six months with the Bosch 808s. Blissful quiet for a few months then the old thud is back |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
I also had the thud when the wipers changed direction. the wiper blades looked okay so tried adjusting the angle of the wiper to the screen many times but had no effect. i noticed there was a lot of sideways play on the little joints that allow the blade to curve round the screen so i gave them a little squeeze in a vice to tighten them up a bit and works perfect, no more thud |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
I always change my wipers each year before MOT.
i think this might be part of the problem .. the fullfats wipers are rather big and heavy so it makes sense that the joints 'might' get a big loose causing the thud.. ... - .- -. Y. O. L. O. . |
Wats39 - could you help me identify which joints you squeezed in the vice. There are several with small rivets to allow rotation Are these the ones? Or do you mean the clips that hold the rubber blade in place? I'm scared to put the riveted joints in the vice in case I break them. Which ones exactly do you mean?
Nomad, it was the 6 joints that pivot back and forth. 2 bigger ones and 4 smaller ones. remember not to squeeze them too tight or the wiper blade wont curve round the screen. they squeeze in pretty easy so even vice grips or plummers pliers should do it ok. '04 td6 se
any chance of a pic , just to help clarify this.. ... - .- -.
I would if i could but cant seem to upload any |
