Home > Maintenance & Mods (L322) > Wiper "thud' on direction change |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
£16/17 or a 40 mile journey.....which is better? ... - .- -.
10th May 2012 10:55am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3778 |
My thud has come back - doh! Geoff |
10th May 2012 10:57am |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 |
I got carried away with this thread and ordered a set off eBay too, even though my "thud" was more of a "gentle bump".
10th May 2012 11:16am |
geoff, that thud you now get might be due to the wipers cleaning the screen to well .... ... - .- -.
10th May 2012 11:19am |
Stan,
10th May 2012 11:24am |
yep my screen is the same , might have to accidentally get a large stone chip but then that will cost me about £70 excess charge..
10th May 2012 11:34am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Ditto after just six months with the Bosch 808s. Blissful quiet for a few months then the old thud is back 2012 5.0L S/C
21st Mar 2013 8:43pm |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
I also had the thud when the wipers changed direction. the wiper blades looked okay so tried adjusting the angle of the wiper to the screen many times but had no effect. i noticed there was a lot of sideways play on the little joints that allow the blade to curve round the screen so i gave them a little squeeze in a vice to tighten them up a bit and works perfect, no more thud '04 td6 se
21st Mar 2013 9:21pm |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
I always change my wipers each year before MOT.
21st Mar 2013 10:25pm |
i think this might be part of the problem .. the fullfats wipers are rather big and heavy so it makes sense that the joints 'might' get a big loose causing the thud.. ... - .- -. Y. O. L. O. . |
22nd Mar 2013 8:26am |
Wats39 - could you help me identify which joints you squeezed in the vice. There are several with small rivets to allow rotation Are these the ones? Or do you mean the clips that hold the rubber blade in place? I'm scared to put the riveted joints in the vice in case I break them. Which ones exactly do you mean?
22nd Mar 2013 12:29pm |
Nomad, it was the 6 joints that pivot back and forth. 2 bigger ones and 4 smaller ones. remember not to squeeze them too tight or the wiper blade wont curve round the screen. they squeeze in pretty easy so even vice grips or plummers pliers should do it ok. '04 td6 se
22nd Mar 2013 1:36pm |
any chance of a pic , just to help clarify this.. ... - .- -.
22nd Mar 2013 1:40pm |
I would if i could but cant seem to upload any can email a pic to you if you pm me your email address and maybe you can upload it if you want? it is just the 6 joints though and not the bits that hold the actual rubber blade on to the wiper so you cant really go wrong '04 td6 se
22nd Mar 2013 1:49pm |
