Home > Maintenance & Mods (L322) > Permanent Live Accessory/Cigerette sockets??
Does anyone know if this is possible on the FFRR at all?
I've seen for D3/D4 that a simple removal of a relay and cross jumper of 2 contact points from the port of the removed relay can do this but wondering if its as simple for the FFRR??
Reason i ask is that i am thinking of going for a BlackVue with GPS..... Smile
Getting far too many near miss's on the way to work lately and need to cover myself should the worst happen, AGAIN Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107776 17th Feb 2012 1:01pm
Both my cig sockets and the boot aux socket are permanently live, so yes it can be done. Probably much as you describe.
The wiring diagrams for the wiring actually offer both permanent live and and ignition controlled cig sockets.
Funnily enough I want to make mine ign controlled.
Post #107779 17th Feb 2012 1:07pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Swap cars?
Post #107781 17th Feb 2012 1:12pm
Maybe we could do a swap Very Happy
having mine Perm live would be good for mobile charging as well as i plan to 'T' into the lighter socket up front and solder ona the charger cable for my phone instead of having to coil the cable up and hang it over the gear stick. Or i could use the feed going to the blackvue in the A Pillar to hang it on the sun visor Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107782 17th Feb 2012 1:13pm
they're big on this blackvue on the disco3 forum, here are a few treads relating to it..
http://www.disco3.co.uk/forum/topic69915.html?highlight=blackvue
http://www.disco3.co.uk/forum/topic70979.html?highlight=blackvue
http://www.disco3.co.uk/forum/topic73082.html?highlight=blackvue ... - .- -.
Post #107785 17th Feb 2012 1:28pm
The 2nd link is exactly why i want it Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107791 17th Feb 2012 1:41pm
there's a cheaper alternative that i've been looking at, its this
http://www.dealextreme.com/p/3-0-mp-wide-a...-lcd-57164 ... - .- -.
Post #107792 17th Feb 2012 1:51pm
I've seen some of these before but the blackvue is much neater and the higher res can be very useful at times (speaking from a security/accident point of view Wink )
The only feature it doesn't have that i would like to see is the ability to use the output as an input and thus have an extension unit pointing out the back, though likely just from the central roof console, to monitor the rear sides for rear end shunts and so fourth.
plus 30fps is great for reconstruction of faces/plates and so on as you get a few frames of data and even at 720p/360 you cna get near hd type print off pictures that can make ID a lot easier Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107796 17th Feb 2012 2:14pm
seems because of the maniac drivers in russia, loads of these are used there for insurance claims.... ... - .- -.
Post #107801 17th Feb 2012 2:44pm
@kingpleb
To make the sig sockets live all the time all you need to do is remove the ignition controlled relay and put a link across the two terminals where the relay contacts were in.
I think the relay is mounted on the rear fuse board.
Can you take a photo of the fuseboard so that I can compare it with mine and try and identify the relay.
We might be able to do two jobs in one. Smile
Post #107835 17th Feb 2012 4:49pm
Ask and ye shall recieve Smile
Post #107836 17th Feb 2012 5:03pm
That was quick Smile
I'll compare it to mine tomorrow, if the rain stops and see if we can identify the relay.
Post #107842 17th Feb 2012 5:27pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
http://www.amazon.co.uk/recorder-Black-vis...amp;sr=8-2
Razz
Post #107848 17th Feb 2012 6:07pm
even cheaper...
http://www.amazon.co.uk/2-5-TFT-Camera-Rec...72-4671537
next... Mr. Green ... - .- -.
Post #107850 17th Feb 2012 6:12pm
@kingpleb
I've checked my fuseboard and have the relays marked with black crosses, I don't have the relay marked with the red circle.
Given the cig sockets are fused by fuse 1 and the fact that the cables serving the cig sockets come off the fuseboard above the red circle relay I think there is a good chance that the red circle relay serves your cig sockets and is ign controlled.
If you remove the relay and turn on your ign I think you will find the sockets are dead.
To make them permanently live you need to look at the removed relay find the two switched contacts and then bridge the corresponding contacts on the fuseboard where you removed the relay.
The link must be capable of 20A.
I think this will work. Laughing
Post #107909 18th Feb 2012 10:25am
