Home > Maintenance & Mods (L322) > Permanent Live Accessory/Cigerette sockets??
Cheers ndfi I'll look into that on my days off this week. Got plenty of cable to replace it with to test and will then use some proper connector and fuse Smile
Thanks for this Smile
Do you want the part number off te relay to order one up? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107918 18th Feb 2012 11:19am
I don't think you will need a fuse. The circuit is already fused.
Just a bit of 20A wire 50mm long with a spade on each end should do, the spades pushed in where the relay was.
Best of luck.
If you could give me the relay number I would be grateful.
Post #107954 18th Feb 2012 3:56pm
NDF i forgot to ask what if anything you have in place of said relay or if it was just blank?!? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #130484 11th Jul 2012 1:45pm
Just a blank space, I assume the necessary link between terminals is on the back of the fuseboard.
Post #130630 12th Jul 2012 7:04am
ooo that is interesting indeed. Have you had yours since new or do you think the previous owner did it?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #130656 12th Jul 2012 9:17am
I didn't do it but in the car wiring diagrams there are two alternative options shown, one for the cigar sockets live all the time and one for the sockets ignition controlled by the relay.
Presumably for different markets. Why mine is the way it is I have no idea.
I now have the best of both worlds by leaving the cigarette sockets live all the time and installing a bank of 4 sockets, ignition controlled for accessories.
Post #130666 12th Jul 2012 9:55am
