Home > Technical (L322) > New Spark Plugs for the LPG
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
My girlfriend bought me new spark plugs for my 2004 FFRR (im still in shock as she done it all off her own back and i had never mentioned it)
She has organised e Denso Irdium Power 0.4mm plugs and yes she got 8
I just wanted to make sure that they would be pre gapped for the 4.4 v8
Does anybody have any idea??
thanks
Neil
Post #99871 30th Dec 2011 11:26pm
Only a 5 minute job to check the gaps
Post #99872 30th Dec 2011 11:30pm
Iridium ones are the good ones for LPG due to the higher heat tolerance Smile
not sure on the gaps for the 4.4 though but just compare to what the spec of standard ones is Smile
Post #99873 30th Dec 2011 11:31pm
cliffy
Cheers guys
Ive just been on denso's website and they state they supply on a 0.9GAP, the part numbers tie up as well she got me IK20's I04's
Post #99877 30th Dec 2011 11:35pm
Also found this for you cliffy Smile
http://www.bimmerfest.com/forums/showthread.php?t=100491
Post #99878 30th Dec 2011 11:37pm
cliffy
Ur a star no gapping the Iridium plugs then Thumbs Up
thanks again u saved me wrecking them
Post #99879 30th Dec 2011 11:41pm
Also means on your next LPG service if they want to remap it your might get a bit better performance out of it and also dont forget your decat Wink
Post #99881 30th Dec 2011 11:46pm
cliffy
Thumbs Up Its going in for its check up from the LPG install so ill be getting it done
Decat sounds good to Bow down
Post #99883 30th Dec 2011 11:50pm
If you can get a salvage exhaust from somewhere with a fubar cat in it and just bash the bits out into a bucket...
local scrappy will likely give you a few quid for the bits to help recoup some of the cost.
Then just bolt the decatted section in and keep the good cats to one side in the garage for a rainy day Smile
And enjoy the noise!
Post #99884 30th Dec 2011 11:56pm
Dolphinboy
How much did your plugs cost? looking to change mine at some point.
Post #99888 31st Dec 2011 12:45am
