![]() | Home > Technical (L322) > New Spark Plugs for the LPG |
Only a 5 minute job to check the gaps |
Iridium ones are the good ones for LPG due to the higher heat tolerance |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Cheers guys
Also found this for you cliffy |
Ur a star no gapping the Iridium plugs then ![]() thanks again u saved me wrecking them |
Also means on your next LPG service if they want to remap it your might get a bit better performance out of it and also dont forget your decat |
![]() Decat sounds good to ![]() |
If you can get a salvage exhaust from somewhere with a fubar cat in it and just bash the bits out into a bucket...
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
How much did your plugs cost? looking to change mine at some point. |
