Home > Maintenance & Mods (L322) > service
Matt@obsidian
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Dan uk. It is the massive one lol, and mean massive that comes in it's own case I guess is best way to describe. It wasn't like a filter you just swap out on a normal car and put the lid back on, it IS the lid as well. I can't see how you could possibly get a "full" service for the money you are talking, I can barely get my civic done for that Shocked Range Rover 4.4 V8 Autobiography
Mustang Mach 1 (1971 in grabber green)
Honda civic 2.2 diesel
VW crafter with ICE
Post #99445 26th Dec 2011 7:51pm
dan_uk_1984
There is an oil filter. An air filter and a pollen filter.
If you know what parts go where its a lot easier to check prices...
The only way I can think it was that expensive is if you had the gearbox oil changed too?
Post #99460 27th Dec 2011 10:04am
@Matt
Are you talking about the transmission oil filter - looks like a big cooking pan with a drain on the bottom? Made of metal?
(on TD6)
Oil filter looks like an oil filter (no metal case, and quite small @ 4" high by 2" diameter)
Air filter is a big white cylindrical filter with a cap on one end (@ 2ft long by 6" diameter)
Pollen filter looks like an old washboard (@2ft x 1ft and about 1" thick) .
Post #99461 27th Dec 2011 10:30am
Matt@obsidian
I've just spoken to the garage owner and he is gonna print me a full break down of parts so I can put them up. I did just assume it was an air filter but I will be better informed hopefully by weekend. But again to the original point, LR did his original services, at prices of about £600, then nearer £1000 with non of the original equipment replaced. They basically took it round to the wash bay and did a visual inspection. When sidmini asked about the "full" service on a 4.4 petrol this was just my experience. A very large bill that basically cost me nothing in labour. Just replacing the plugs, the industry standard is n hour and a half, and the plugs being platinum must be £70 ish? So that's £70 plus say £30 labour? So that's £100 right there. I can't see how you can change 9 litres of expensive oil, top or replace other fluids, change 3 or 4 filters (I believe it has 2 air filters but again could be wrong) all for a "maximum" of £300. But again, I will try to bring a full break down for a more informed view Range Rover 4.4 V8 Autobiography
VW crafter with ICE
Post #99464 27th Dec 2011 12:43pm
Renegade2
I have a TD6 2005 which i had from new and it has 56k on the clock, i decided that now it is out of all warranty i would do a service myself as i am fed up taking back the tools they leave in the engine!!
i got all the parts from Brit parts and the oil fromm halfords as they had 20% off. I decided that i would also replace the crakcase valve whilst i had it apart rather than just the filter. Started at 2pm on Saturady and finshed at 7pm and that is the first time i had done one, learnt a few lessons on the way and i rekon i could do in half the time next time. I used the post on Wiki as a guide and was indeed very helpful. The most exspensive part was the oil plus i did a engine flush.
Air Filter K & N Cotton £32
Oil Filter £8.40
Fuel Filter £9.41
New oil drain plug and washer £3.71
Pollen filter £15
Crankcase filter and valve £39
Small air filter near fuel filter £1.68
9L Castrol Edge 5/40 synthetic £82
2 cans Wynns engine flsuh £9.98
Everything was done meticously and everything was also cleaned whilst the covers where off. The parts and oil came to about £200 albeit i replace the crankcase valve and upgarded the filter. The dealer one just lloks like a oice of cardboard with cotton wool wrapped around it. I would say that the dealer would not have done such a good job but charged me a lot more in Cardiff, plus i have issues with them.
If any one wants to do a service and not sure pm me and i am happy to point out the bits that i went wrong on and soon worked out what to do............more importantly than all the above I really enjoyed doing it and felt good afterwards.........oh apart from the oil spill on the block driveway which the Mrs went nuts about!!!!!!!!!
Do the transfer box and diffs next
Post #100973 9th Jan 2012 11:19pm
