Home > Technical (L322) > What is the dot above odometer? |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
I thought that meant its been tampered with at some point, if its warning you a small triangle appears both sides of the display Reformed |
14th Dec 2011 9:07pm |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
as in the mileage altered?
14th Dec 2011 9:14pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Im sure it means something has changed. The mileage is stored on several ECU's. Off the top of my head the dash binical ECU and the BCM ECU, if either has been changed with and older or newer one the dot appears to show a miss match. The ecu's will show the higher mileage. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
14th Dec 2011 9:32pm |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
Have you got a pic?
14th Dec 2011 9:34pm |
Very good! I wondered whether it was a mark but it is on the display.
14th Dec 2011 9:40pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
the mileage is held in the clocks,LCM and main ecu, if any of these are change you will get the dot appear, if a new unit is fitted then it will be coded to your car and the correct mileage inserted.this can only be done once. V8 facelift Range Rover Autobiography 22" wheels.
14th Dec 2011 9:51pm |
As Daveo said. Sounds like they have used a spare/pre used LCM which obviously has a different mileage stored and the miss match is causing the dot. If they change it back will the Dot go? That's the million dollar question I would be asking. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
14th Dec 2011 10:26pm |
if they put your unit back it should be fine but i would want to know why they have gave your car back with a used and unregistered unit on your car..what did your car go in for V8 facelift Range Rover Autobiography 22" wheels.
14th Dec 2011 10:43pm |
